#1 Posted : Saturday, 20 January 2007 10:56:20 PM(UTC)
I have an EL falcon running LPG only. It lacks power and i am wondering what I can do to the power back to wfere it should be.
The car drives Okay, just a bit gutless.
I have replaced the coil, TFI module, cap, rotor, leads, plugs (gas plugs). The cat has been broken out. I would love some ideas.
#2 Posted : Wednesday, 31 January 2007 12:59:19 AM(UTC)
See my other post in regards to tailshaft. Also my EB on gas was a tad gutless. I fitted it with one of those 2.5 inch cat back Redback exhausts & now it goes a heap better.
Gutting the cat won't make any difference. I ran a gutted cat for a while due
#3 Posted : Wednesday, 31 January 2007 2:10:45 AM(UTC)
There is actually something amiss with the car. I am not trying to increase performance-just restore it. The car doesn't have the power that it should have from standard with a gas system fitted. I reckon that a sensor is faulty but so far have not been a
#4 Posted : Wednesday, 31 January 2007 9:26:10 PM(UTC)
how many Km has it done? how much of that has been done on gas? & did you lose the power suddenly or gradually?
Sorry i got the impression that it lacked power due to the gas conversion which is understandable.
Here is the link to another reaso
Edited by user Wednesday, 31 January 2007 9:30:36 PM(UTC)  | Reason: Not specified
#5 Posted : Wednesday, 31 January 2007 11:17:05 PM(UTC)
Since I have had the car, about two years. It is an ex cab and done 820 000.
Compresion is OK.
#6 Posted : Thursday, 1 February 2007 2:25:11 AM(UTC)
820,000Km I would guess that your timing chain may be stretched causing retarded valve timing (which won't effect ignition timing). My EB suffers from this & it's only done 460,000. Then again at idle especially when cold my timing chain rattles a bi
#7 Posted : Thursday, 1 February 2007 2:57:55 AM(UTC)
Yeah no rattle at all. I might just do a rebuild on it and start from the ground up.
Guest (6)
