#1 Posted : Monday, 22 January 2007 9:34:09 PM(UTC)
Howdy,
Got heaps of questions regarding my return to V8 land after bub's grown up & the missus goes back to work.
Does the TH700 have an overdrive? Will it fit in a trimatic tunnel (HG) or will there have to be modification to make it fit? What model commie's are they from & do they need a computer or can they function with a carb'd engine? What's the model for the v6? I assume it'd be more common & cheaper, & I assume that it'd handle a mild 308....?
The Beige Hornet.
#2 Posted : Monday, 22 January 2007 10:44:03 PM(UTC)
TH700R4 is a 4spd auto with lockup torque converter. Full hydraulic versions can be found in VN and VP Commodores. VR onwards use the electronic 4L60E. The TH700R4 can be put behind a carbied V8 in a HG, but you will have to do some mods to the crossmembe
Mr Void Offline
#3 Posted : Tuesday, 23 January 2007 10:14:36 AM(UTC)
Mr Void
Hey Byron I always thought that only SI VN's had the full hydraulic TH700's cause they will hold 1st forever whereas the others will change up to 2nd? What was changed there?
___________________
Why are you reading this, you should be looking up ther
___________________
