#1 Posted : Tuesday, 23 January 2007 2:20:26 AM(UTC)
were does an oil pressure gauge tube screw into on a 253 ? cheers
#2 Posted : Tuesday, 23 January 2007 2:33:35 AM(UTC)
There should be a fitting on the top of the oil pump, which is the bit the oil filter screws on to.
The Beige Hornet.
#3 Posted : Tuesday, 23 January 2007 3:27:32 AM(UTC)
Just be careful how big the sender unti is, mine barely clears the alternator.
Munromad2004 Offline
#4 Posted : Tuesday, 23 January 2007 8:46:55 AM(UTC)
Munromad2004
It sounds like you are talking about a mechanical oil pressure gauge as you mentioned a tube.
The Holden V8's run an electrical gauge which uses a sender unit to run the gauge.
Mechanical type gauges are the type that use an actual oil line plumbed to
Edited by user Tuesday, 23 January 2007 8:51:51 AM(UTC)  | Reason: Not specified
