kanks Offline
#1 Posted : Wednesday, 24 January 2007 8:17:21 AM(UTC)
kanks
CAN ANY ONE TELL ME THE DIFFERENCE BEETWEEN HT/G/K GEAR BOX CROSSMEMBER ANY HELP THANKS
#2 Posted : Wednesday, 24 January 2007 7:34:51 PM(UTC)
Crossmembers are different for different gearboxes, but for the same box HT and HG are the same and mount on outriggers hanging backwards off the front subframe. Whereas HK are mounted to the floor body member like a HR.
_______________________________
kanks Offline
#3 Posted : Thursday, 25 January 2007 7:17:11 AM(UTC)
kanks
thanks 4 the info .i bought a 307 which came with a turbo 700 with turbo 350 internals motor and box are a complete conversion out of hk but it will be going into hg it also came with custom crossmember just wondering do i mount on brackts or to floorthan
#4 Posted : Thursday, 25 January 2007 5:28:42 PM(UTC)
No. Just use a HT Trimatic crossmember, as HT/G crossmembers slide backwards and forwards with lots of different mounting points. You still might have to adjust it for height though.
If we all ha
