CAN ANY ONE TELL ME THE DIFFERENCE BEETWEEN HT/G/K GEAR BOX CROSSMEMBER ANY HELP THANKS
Crossmembers are different for different gearboxes, but for the same box HT and HG are the same and mount on outriggers hanging backwards off the front subframe. Whereas HK are mounted to the floor body member like a HR.
_______________________________ |
thanks 4 the info .i bought a 307 which came with a turbo 700 with turbo 350 internals motor and box are a complete conversion out of hk but it will be going into hg it also came with custom crossmember just wondering do i mount on brackts or to floorthan
No. Just use a HT Trimatic crossmember, as HT/G crossmembers slide backwards and forwards with lots of different mounting points. You still might have to adjust it for height though.
_______________________________________________________ If we all ha |
