boom Offline
#1 Posted : Thursday, 25 January 2007 1:55:02 AM(UTC)
boom
Hey all,
My Uncle is a big fan of german engineering and has bet me that a stock 2.0 litre FSI Volkswagen golf would be more powerful than my recently acquired 186 once i've finished modifiying it.
I need some quick power ups that are under a strict budget of no more than $200.
I was reading an article in street machine (my monthly sanity) about a grunt hunt on a blue 202. They extracted nearly 200 hp out of it.
An interesting point was that removing the air filter and fixed blade fan and replacing these parts with aftermarket pieces extracted nearly 24 HP! i already have a 350 holley ready for the job. I'm also cheaply sourcing a blue 202 head (12 port). Any help in this are would be appreciated (i'm looking at you Byron Rich)!
I know the Golf puts out about 110kW (about 147HP)
Cheers Boys!
Alex
R.I.P Peter Brock - He was a living legend
Edited by user Thursday, 25 January 2007 5:28:35 AM(UTC)  | Reason: Not specified
#2 Posted : Thursday, 25 January 2007 2:58:51 AM(UTC)
The golf might put out more kw but hook a 21 foot caravan up and see how it goes.
boom Offline
#3 Posted : Thursday, 25 January 2007 5:31:15 AM(UTC)
boom
You're not wrong mate, I think we'll have a series of tests, you know drags, burnouts, sound off, pulling caravans, but you can stick economy up your arse because american machinery is built for power.
#4 Posted : Thursday, 25 January 2007 6:27:28 PM(UTC)
I think its a bit of "horses for courses ". Depends on what the 186/202 is in.... 400 m sprint .. In a Kingswood... my money would be on the Golf. Put the same motor in an early LC/LJ Torrie and it woould be bye bye Golf.
Doing any work..towing the Car t
#5 Posted : Thursday, 25 January 2007 8:06:26 PM(UTC)
Do you want power or reliability?
If you want power only, forget the blue 202 head and get a modified 149 or 161 or 173 red head. This will bump your compression up to about 10:1, stick a Holley with 4 barrel manifold or triple SU's and a 30/70 cam (in o
Edited by user Friday, 26 January 2007 2:05:25 AM(UTC)  | Reason: Not specified
#6 Posted : Thursday, 25 January 2007 9:56:09 PM(UTC)
If you are quick here is your 186 stroker ie 202:
http://cgi.ebay.com.au/y...9700QQrdZ1QQcmdZViewItem
I
boom Offline
#7 Posted : Thursday, 25 January 2007 11:45:37 PM(UTC)
boom
Mate I think i'll stick with the red head from a smaller motor. Holley 350's add more power on the reds (as apposed to nothing on the 202). Is a 208 just a 186 with a 202 crank?
Thanx
Alex
#8 Posted : Friday, 26 January 2007 2:02:16 AM(UTC)
Yes, but like a 192 there is no real such tangible thing as a 208. It's a 202 that has been rebuilt with +0.060" pistons. A 202 is a 186 with a 202 crank, simple as that. Same parts, same strength, same hotting up tips. 350 Holley works as bad (or good, d
boom Offline
#9 Posted : Friday, 26 January 2007 2:18:42 AM(UTC)
boom
Mate the thing is, i dont have a 202, i have a 186. what do you mean by modified 149, 161, 173 head? do you mean shaved and ported or do you mean a yella terra head?
#10 Posted : Friday, 26 January 2007 3:52:21 AM(UTC)
Exactly. The 149, 161 and 173 high comp heads have smaller chambers and will increase the compression ratio of a 179, 186 or 202 high comp motor to over or about 10:1. This is basically how Holden made the XU-1 engines. By modified I do mean worked, like
FastEHHolden Offline
#11 Posted : Friday, 26 January 2007 6:15:24 AM(UTC)
FastEHHolden
Hope you aren't betting pink slips.. I don't know what your uncle will do with his new Holden.
boom Offline
#12 Posted : Friday, 26 January 2007 8:42:16 AM(UTC)
boom
I can tell you now if we were racing for pinks nobody and i mean NOBODY would ever go near my pride and joy, let alone drive off with it. would your eh beat a golf?, it's alot heavier than a torana. But thanks for your support man i appreciate it.
R.I.
#13 Posted : Friday, 26 January 2007 11:55:51 PM(UTC)
FastEHHolden
No it wouldn't..and I think you might find the golf might be skinnier than an LC/LJ.
boom Offline
#14 Posted : Saturday, 27 January 2007 2:42:21 AM(UTC)
boom
I don't give a ****. The Golf may have 147 horses behind it, but my torana will have the golf behind it.
#15 Posted : Saturday, 27 January 2007 8:48:54 AM(UTC)
FastEHHolden
Keep us posted...I am interested to hear the outcome.
Mr Void Offline
#16 Posted : Saturday, 27 January 2007 8:36:38 PM(UTC)
Mr Void
What diff gears and gear box are you running?
..and how much older than you is your uncle? Personally I think the wager he provoked is like (presuming he is a good couple decades older than you) you saying to him that you should both have a running, jump
___________________
boom Offline
#17 Posted : Saturday, 27 January 2007 10:00:44 PM(UTC)
boom
I was thinking of running 4.44 gears and i'm getting either an aussie 4spd
or a supra/celica 5spd.
He's alot older than me actually.
And i've got alot of parts already (carb, manifold, electronic dizzy, e.t.c) the budget will probably stretch further,
Guest (10)
