vulcan2509 Offline
#1 Posted : Thursday, 25 January 2007 4:48:06 AM(UTC)
vulcan2509
Driving the HD to work today, took of from the lights and she just died.I poped the Bonnet cheaked fuel that was good. Cranked her over and thats all I got just cranking. Pulled No 1 plug to check spark and she fired up. Replaced the plug she fired up no probs. Then on the way home she did it again so I repeated my last and of we go again. On inspecting the plug I noticed a slight crack in the ceramic. WOULD THIS CAUSE THIS PROBLEM???????
Eddie
"With A Name Like Brock What Else Would I Drive"
#2 Posted : Thursday, 25 January 2007 5:15:43 AM(UTC)
yes but one plug should not completely kill the motor just run rough check the other plugs
#3 Posted : Thursday, 25 January 2007 8:52:48 AM(UTC)
Try a coil and or coil lead and check the power wire to the coil.As johnperth said a plug will only cause a missfire not a engine stop
David Offline
#4 Posted : Friday, 26 January 2007 2:30:35 AM(UTC)
David
Hi Mate,
Might be worthwhile also checking (or just replacing) the condenser. The condenser can break down when hot, and motor will stop. After a while it cools, then motor will start. Maybe the time it took for you to fiddle about, check plug, etc (15
vulcan2509 Offline
#5 Posted : Friday, 26 January 2007 5:38:15 AM(UTC)
vulcan2509
Had the same problem this morning, and DAMN it happened in a bad spot to, nearly got run under. Nursed it to a servo did a little thinking and a little fault finding. Figured my HT lead from the dizzy to the coil may have been breaking down. Drove to work
