#1 Posted : Saturday, 19 May 2007 9:38:13 AM(UTC)
Hi all,
just had car serviced and tuned within last 3 or 4 weeks. running like a dream (actually had to turn radio off to make sure care was still running - not bad for 308). anyway, late last week it began running quite rough and stalling when at a stand still. thought it may be fuel related (dirty, clogged carb etc) all checks out no problems. so went driving at night - rough idle and stalling much worse at night. looked at the battery guauge on a HZ gts dash - and at a stand still the volt meter just slowly began creeping down - then would begin to idle roughly and stall.
so here is my question - i have had distibutor and coil checked only last friday - alls good. so can a crappy alternator or battery be causing my rough idle, stalling and ever slowly draining volt gauge.
cheers geoff
KiwiHQ Offline
#2 Posted : Saturday, 19 May 2007 5:07:21 PM(UTC)
KiwiHQ
I had the same thing the other day. I filled up the car with gas and went on a 15 minute highway run. When i had finished the idle was ok again. Sometimes i get dirty fuel blocking the carb is my guess. Naturally it only happens when i am being lazy a
Rock n Roll
#3 Posted : Sunday, 20 May 2007 8:20:20 PM(UTC)
It sounds like the Alt is the problem. The alt should be charging at about 13.7 to 14.2 volts running and about the same with the headlights on.If the headlights/dashlights are getting dimmer the longer you drive, it also shows that you are running out of
#4 Posted : Sunday, 20 May 2007 11:03:45 PM(UTC)
Definetly not fuel, as the car is idling perfect again. but still staling when in drive and at a stop (stop lights). will give the alternator trick a whirl. thanks for tip hq ss. hopefully it is just a dodgy alternator.
cheers geoff
trubluhq Offline
#5 Posted : Saturday, 26 May 2007 8:53:56 PM(UTC)
trubluhq
Sorry to resurrect an old case, but very much along these lines.
HQ drives AOK, auto gear change is fine, yet the HQ will stall intermittantly with a rough idle. To cut a long story short went thru all the usual checks. No answer.
For some reason I
trubluhq Offline
#6 Posted : Tuesday, 29 May 2007 10:13:18 AM(UTC)
trubluhq
OK - Rare Spares had the part...vacuum now at 20"/mG at idle and 30+ downhill....strewth....would suck at zit at 400m at that rate.
Idle probs all gone, & accel is back with a vengance..yipppeee.
Cheers J
#7 Posted : Tuesday, 29 May 2007 4:17:58 PM(UTC)
John
Why do you think you would have no advance at all with a buggered vacuum advance module? The centrifugal mechanism should still have worked, just no vacuum topup in high vacuum conditions like highway cruising. You should have regained a few MPG too
trubluhq Offline
#8 Posted : Saturday, 2 June 2007 5:21:01 AM(UTC)
trubluhq
Hi Byron,
I agree its no such much it was not working. The diaphragm had a hole in it. So it was leaning the mix out by sucking pure air thru the dizzy. Just like a carby not seating properly. And with 5"/mg vac at idle...the 253 is hardly getting enou
This page was generated in 0.092 seconds.
