Fred Offline
#1 Posted : Saturday, 27 January 2007 8:29:54 AM(UTC)
Fred
Is the 253 the same block as the 308, is it correct that the same gearboxes will both up on both engines.
God is Dog spelt backwards.
FastEHHolden Offline
#2 Posted : Saturday, 27 January 2007 8:52:43 AM(UTC)
FastEHHolden
yes and no...all 253 are aussie pattern blocks.
308 comes in aussie and turbo pattern.
So an aussie 4 speed or trimatic will bolt up to any 253 and some 308's....a turbohydramatic 350 or 400 will bolt up only to some 308's.
#3 Posted : Saturday, 27 January 2007 8:55:52 AM(UTC)
Yes & no.....
While it is the same block externally, the bores are smaller, and the cores aren't as accurate as a 308, meaning that if you bore it out to the 4" bore of a 308 you risk hitting water.
As far as gearboxes, yes they interchange betwee
#4 Posted : Saturday, 27 January 2007 9:00:12 AM(UTC)
Beat me to the punch there FastEH! (now I know where you got your username!)
Here's an old turbo/tri thread with a very useful picture in it:
http://www.fastlane.com....D=7804&SearchTerms=turbo
____________
