#1 Posted : Monday, 21 May 2007 5:02:49 AM(UTC)
Will a WB Stateman dash fit in my HQ tonner???
Thanks in advance!
Matthew
#2 Posted : Monday, 21 May 2007 5:15:52 AM(UTC)
yes but you must swap the inner metal dash over -big job but can be done, some cutting/welding involved
#3 Posted : Monday, 21 May 2007 5:53:19 AM(UTC)
Does that require engineering?
When you say 'big', how big we talking????
#4 Posted : Monday, 21 May 2007 7:47:55 AM(UTC)
Just unpicking of spot welds and "migging" the new support in.
#5 Posted : Monday, 21 May 2007 8:20:09 AM(UTC)
i wouldn`t think an engineers report would be needed but check with your rta to be sure.
#6 Posted : Monday, 21 May 2007 9:07:28 AM(UTC)
_____________________
#7 Posted : Monday, 21 May 2007 4:20:08 PM(UTC)
No. Not hard, just time consuming.
CheckM8 Offline
#8 Posted : Monday, 21 May 2007 11:52:23 PM(UTC)
CheckM8
Im in Bendigo, VIC. Can you recommend anyone to undertake this kind of work?
Give so the mo can grow!
All donations can be made here- http://au.movember.com/mospace/102789
Support Movember!
RdS Offline
#9 Posted : Tuesday, 22 May 2007 2:51:48 AM(UTC)
RdS
im pretty sure any sort of panel beaters will be able to do this. wiring would be the big issue for me!
4/76 HJ monaroGTS
4/76 HJ monaroGTS
CheckM8 Offline
#10 Posted : Tuesday, 22 May 2007 9:18:24 AM(UTC)
CheckM8
Wiring shoudnt be much of an issue. Wont be using most of the standard Stato feature i.e. guages. Running full custom autometer setup.
Appreciate all the info guys!! Thanks!
Anything else anyone wants to add, please do!
Support Movember!
CheckM8 Offline
#11 Posted : Tuesday, 22 May 2007 9:20:21 PM(UTC)
CheckM8
Just another question, is the inner metal dash the same as the WB off any other models i.e. HJ, HX, HZ etc???? Or do i have to source the inner metal dash off the WB itself?
Support Movember!
This page was generated in 0.095 seconds.
