Will a WB Stateman dash fit in my HQ tonner???
Thanks in advance!
Matthew
yes but you must swap the inner metal dash over -big job but can be done, some cutting/welding involved
Does that require engineering? When you say 'big', how big we talking????
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
Just unpicking of spot welds and "migging" the new support in.
i wouldn`t think an engineers report would be needed but check with your rta to be sure.
No. Not hard, just time consuming.
Im in Bendigo, VIC. Can you recommend anyone to undertake this kind of work? |
im pretty sure any sort of panel beaters will be able to do this. wiring would be the big issue for me!
4/76 HJ monaroGTS |
4/76 HJ monaroGTS |
Wiring shoudnt be much of an issue. Wont be using most of the standard Stato feature i.e. guages. Running full custom autometer setup.
Appreciate all the info guys!! Thanks!
Anything else anyone wants to add, please do! |
Just another question, is the inner metal dash the same as the WB off any other models i.e. HJ, HX, HZ etc???? Or do i have to source the inner metal dash off the WB itself? |
