#1 Posted : Saturday, 3 February 2007 2:29:46 AM(UTC)
this may not be acar question but ihave alarge floor jack when i crank it up it comes back down i twist the handle tight could someone tell me how to fix it ? cheers and thanks
ChrisHQUTE Offline
#2 Posted : Saturday, 3 February 2007 3:14:37 AM(UTC)
ChrisHQUTE
Sounds like there is a bit of grit thats got into the hydraulic valve. Not a easy fix a lot of those jacks can be very temperamental. I would suggest loosening the two plugs on the top of the pump block, pump the handle a few times and tighten plugs back
If a man say's something in the woods and there is no women around, is he still wrong?
#3 Posted : Sunday, 4 February 2007 10:51:14 AM(UTC)
If the main seal is u/s it will also do what you describe.
