#1 Posted : Friday, 25 May 2007 3:00:41 AM(UTC)
hi have a vp v6 ,around town lucky to get 400km t a tank
anyone had any success of geting it any better, like changing the oxygen sennsor etc
#2 Posted : Friday, 25 May 2007 4:26:26 AM(UTC)
Hi petaus.
It's best to calculate exactly what economy figures you're currently getting. I do this for a living & the 2 things you have to do before you even open the bonnet is, 1. check that your speedometer (or odometer) is correct (most aren't) and
#3 Posted : Tuesday, 29 May 2007 2:52:43 AM(UTC)
hi terry speedo is correct worked first tank i used e10 fuel i got 15.4 lts/100km then used mobil standard unleaded (not sure if it contains any ethnol) got 13.2 lts/100km, might try high octane next.
i was going to try a kn air filter and plantinum plug
#4 Posted : Tuesday, 29 May 2007 8:35:39 AM(UTC)
Hi petaus.
13.2 L/100 km is a good figure for Sydney traffic. By all means try hi-octane, but I would check more tank-fulls than just one. I'm surprised by the difference of over 2 L/100 km between E10 & standard unleaded, it's usually around 1 to 1.5
jabba Offline
#5 Posted : Tuesday, 29 May 2007 4:08:00 PM(UTC)
jabba
When I used a K&N pod filter on my VR (3.8), I went from 500K per tank mixed driving to around 550K. The best I ever got was a cold weather run from Wellington to Auckland, where I managed just over 700K from the tank.
________________________________
