#1 Posted : Saturday, 26 May 2007 2:40:28 AM(UTC)
i know how to get 12 volts to the coil useing the yellow wire from the ignition switch but do i line up the reluctor bumps in the same spot as the points dizzy ? ps and to use the right coil cheers
#2 Posted : Saturday, 26 May 2007 2:54:42 AM(UTC)
Hi john.
Yes, that's how you get is close enough to start, but to get it spot-on you will need to use a timing light.
Dr Terry.
