#1 Posted : Sunday, 18 February 2007 7:00:20 AM(UTC)
How ya goin guys ,I rebuilt a 202 red motor with celica 5spd conversion for my LC Torana with bathurst specs to rev to 9000rpm ,i had the flywheel snap and twist and break the bolts ,i have original flywheel bolts but arent sure of the tensile grade of them?I can get aftermarket grade 8 tensile bolts but they have a different head and look like hardware bolts....Whats the maximum torque setting on the standard bolts??I would like to torque them to 95 pounds but they may snap,or go for the aftermarket bolts??Am absolutely confused as to what will hold up to a hot motor????Cheers
#2 Posted : Sunday, 18 February 2007 7:57:04 AM(UTC)
hmmm dunno what was standard but its not unusuall for high tensile bolts to snap like that, often happens on earthmoving equip. only fix for it is to use a lower tensile grade of bolt
peter_flane Offline
#3 Posted : Sunday, 18 February 2007 10:08:10 AM(UTC)
peter_flane
Ummm whoever built the motor should be able to get proper flywheel bolts for you.
#4 Posted : Sunday, 18 February 2007 6:39:59 PM(UTC)
#5 Posted : Sunday, 18 February 2007 6:46:13 PM(UTC)
Fly - did you check the bellhousing alingment, flywheel runout? could be off a little causing extra vibes and stress. I had some offset dowles made when I did a conversion, was out .030" just a thought.
Sandman Offline
#6 Posted : Sunday, 18 February 2007 9:19:08 PM(UTC)
Sandman
Get some ARP bolts. Worth the money. Probably worth replacing the ones in the clutch as well.
I presume everything is balanced well, and when you got it balanced, you told who was doing it how hard you were planning on revving it to??? 9000rpm is a lotta
BrianH Offline
#7 Posted : Sunday, 18 February 2007 11:44:54 PM(UTC)
BrianH
Fly
Sandman is right about the balancing etc and 9000 is a hell of a lot of revs. At that speed there is no room for guessing and you will need the best of everything in that engine if you want it to stay together.
I have an old edition of US Hot R
Sandman Offline
#8 Posted : Monday, 19 February 2007 6:20:30 AM(UTC)
Sandman
Yeh, it's a scary thought to have flywheels come off at high revs, not just for the driver, also anyone else in the line of fire.
I saw one come off a 308 HQ at high revs in a burnout comp. Luckily no-one was injured. Wrote the car off. Even took the g
74HJLS Offline
#9 Posted : Monday, 19 February 2007 8:22:54 AM(UTC)
74HJLS
G'day Pete,
Hows Roma treating ya? Got the Munro registered, a ball to cruise around in, you can check it out at, http://gallery.oldholden.com/Petes-Monaro/
Pete.
Pete.
#10 Posted : Monday, 19 February 2007 9:49:55 AM(UTC)
that is a lot of revs especially for a 202. To be honest I doubt the rpm. And what does it prove? probably ran out of usable torque at 7500. Under NO circumstances go to lesser bolts. Holden did not put expensive hi tensile bolts in if cheap hardware stor
#11 Posted : Tuesday, 20 February 2007 6:36:03 AM(UTC)
Munro looks great Pete. Let a message on ur site. PW
#12 Posted : Tuesday, 20 February 2007 7:01:00 AM(UTC)
yeah sorry i should've went on to say what work on a pto drive on ya tractor aint to good on ur clutch id be gettin the best HT bolts i can find and double checking that torqe setting for em
#13 Posted : Tuesday, 20 February 2007 9:46:40 AM(UTC)
I wonder if this is a genuine post. 9000 rpm is an awful lot. what sort of street motor would it be?
I think we bin had
Sandman Offline
#14 Posted : Saturday, 24 February 2007 4:57:14 AM(UTC)
Sandman
Yeh John,
Maybe he should get the tacho checked as well as the flywheel bolts. haha
Guest (7)
This page was generated in 0.082 seconds.
