#1 Posted : Monday, 19 February 2007 10:36:09 AM(UTC)
i recently bought a 97 VS S pack ute n had an after-market head unit n 6inch speakers i wanted to install. i have no idea on how to get the stock cassette deck out?! any ideas? also, where should i put my 6inch speakers? was thinking on the shelf just below the back window in boxes behind the head rests? what do u reckon?
Cheers!
#2 Posted : Monday, 19 February 2007 7:11:41 PM(UTC)
Do you have a bench seat or buckets? Big differences in the way it's done depending on this.
A lot of people aim to achieve nothing in life - and have amazing accuracy
#3 Posted : Tuesday, 20 February 2007 2:19:12 AM(UTC)
Bucket seats cos i got a centre console
#4 Posted : Tuesday, 20 February 2007 4:56:49 AM(UTC)
OK, speakers first.
Your handbrake is in the centre, so you can fit the full length door pockets from a VR or VS (if you don't already have them). 6 inch speakers fir perfectly into them.
As far as the head unit, you need to remove the console cove
Edited by user Tuesday, 20 February 2007 4:57:55 AM(UTC)  | Reason: Not specified
#5 Posted : Tuesday, 20 February 2007 10:57:18 AM(UTC)
Thanks heaps for that Mick! Really good site! Just having a little trouble removing the centre console. i have removed the two screws in the storage of the console and have tried lifting the whole thing up n pulling it backwards, with success on the left
#6 Posted : Tuesday, 20 February 2007 6:28:54 PM(UTC)
You need to pop up the "cap" that covers the gear lever area to get to that screw & it's matching partner on the RHS.
To do that, pull out the ashtray, and use the hole as a handgrip to pull up on it enough to get a screwdriver into the gap that forms
#7 Posted : Tuesday, 20 February 2007 10:03:58 PM(UTC)
Maybe I misread it but didn't see a mention of undoing the two screws at the front of the console that lower it down for easier removal.
I got the stereo out of the wife's VP in about 1/2 hour the other day & I wasn't rushing (but I have done it se
#8 Posted : Thursday, 22 February 2007 8:48:37 AM(UTC)
Alright stereo in(only took 2.5 hours! lol) thanks for the help! next thing speakers. i found six of the easy screws to find on door pockets n around the air duct, yet i know there must be more cos i cant take it off yet! where bouts r they n how many mor
#9 Posted : Thursday, 22 February 2007 5:03:58 PM(UTC)
When you undo the screw on the finishing plate of the vent (the bit that closes against the dash) you can remove it (bit of a struggle).
Then pop the vents out of the housing - push on the back of them to force them, and gently use a small screwdriver
This page was generated in 0.125 seconds.
