Bossy Offline
#1 Posted : Sunday, 25 February 2007 12:33:06 AM(UTC)
Bossy
I have just put a 250 pre-xflow, XW brakes and diff into an XP. What do I need to do register it? Do I need a engineering cert? What else do I need to do in QLD???
Paul351xb Offline
#2 Posted : Sunday, 25 February 2007 8:13:02 AM(UTC)
Paul351xb
Bossy, give Queensland Transport a call. They will tell you all the hoops you have to jump through. I don't think you'll have too many problems but best to call them as its their rules you have to follow.
Paul.
I_am_josh Offline
#3 Posted : Sunday, 25 February 2007 11:46:41 AM(UTC)
I_am_josh
Engineering certificates relate mostly to modified parts, rather than factory bolt-ons.
If the gear fitted straight up, you'll nary have a whisper of trouble.
But if things have been welded or cut down to fit, you may have a problem or two.
Or you just
<<<just me>>>
Bossy Offline
#4 Posted : Wednesday, 28 February 2007 7:16:22 AM(UTC)
Bossy
Bossy Offline
#5 Posted : Wednesday, 28 February 2007 7:17:05 AM(UTC)
Bossy
#6 Posted : Thursday, 1 March 2007 10:35:00 PM(UTC)
you wont need an engineers certificate for the mechanicals, but you may in QLD for the fitting of the engine. As you are only allowed to go a certain percentage over the original before you need this. They will then make sure brakes are adequate. Brakes n
