keithholden Offline
#1 Posted : Sunday, 25 February 2007 9:12:37 AM(UTC)
keithholden
I have drums on the front of my XW and I see some xf disc brakes for sale for 70$ and was wondering if they would fit on my Xw or if I have to get Xy disc brakes.. even then will XY ones fit ??
Cheers again for any help you guys are the best
Keith
stopgo Offline
#2 Posted : Sunday, 25 February 2007 11:12:23 PM(UTC)
stopgo
Ring Peter at Hopper Stoppers
He can talk you thru it
You'll need the spindle too
keithholden Offline
#3 Posted : Monday, 26 February 2007 1:14:26 AM(UTC)
keithholden
Im in that cold horible plac new zealand .. I mean that warm beautiful place.
Whats a spindle? here is alink to the brakes
http://www.trademe.co.nz...isting.aspx?id=88967910
Paul351xb Offline
#4 Posted : Monday, 26 February 2007 2:26:23 AM(UTC)
Paul351xb
The spindle is what the disc rotor bolts to. Best bet is to go to a wrecking yard and get everything you need off a wreck. There must be plenty of dead XFs still laying around the place. You'll probably have to put a new master cylinder on the car as w
#5 Posted : Friday, 2 March 2007 2:25:13 AM(UTC)
You will need to replace your master cylinder or remove the residual line pressure valve from the front circuit of yours ti fit disc brakes. Yes the XF ones will fit as long as you use the XA-XF disc brake sub axle.
also see topic: http://www.fastlane
