jphick Offline
#1 Posted : Tuesday, 29 May 2007 5:51:43 AM(UTC)
jphick
A few more (Hopefully!!!!!)
Edited by user Tuesday, 29 May 2007 7:03:59 AM(UTC)  | Reason: Not specified
wallywa Offline
#2 Posted : Wednesday, 20 June 2007 10:44:41 PM(UTC)
wallywa
Nice Wagon !!!!!!!!!
Mark
Mark
Mark
#3 Posted : Sunday, 8 July 2007 11:30:31 PM(UTC)
Cheers Mark,
Do you have any pics of the Overlander wagon I see there under your username?
jphick.
#4 Posted : Wednesday, 31 October 2007 2:25:24 AM(UTC)
yes i have that same problem in my hj wagon, its ****s me to no end. i found a petrol
station that is on a lean so i havta go there to fill up
jphick Offline
#5 Posted : Sunday, 4 November 2007 2:03:43 AM(UTC)
jphick
Thanks OzyGunja,yep the fuel refill is a bit of a mess.
Im thinking of putting a 253 in the HZ to replace the 202 for power and mileage improvement.Has anyone experience with that?
RdS Offline
#6 Posted : Tuesday, 6 November 2007 2:11:45 AM(UTC)
RdS
bloody beutiful. :) so much more stylish than the newer holden wagons.
got a bit of a soft spot for them too. had a White HZ wagon, then a burgandy HZ wagon growing up..
4/76 HJ monaroGTS
4/76 HJ monaroGTS
jphick Offline
#7 Posted : Tuesday, 6 November 2007 7:03:06 AM(UTC)
jphick
Cheers RDS .Had a HQ Sedan before this but love the HZ Wagon
#8 Posted : Thursday, 1 January 2009 6:59:07 AM(UTC)
gday mate, real nice wagon there, for the swap you will need engine, go trimatic for simplicity, then your tailshaft will slide straight in, if your gentle on her, the six cyl diff and tailshaft will more than do the trick, but otherwise you would need front v8 springs, and you should be away.
i would recommend a set of tri y extractors, with 2 1/4" collectors into a 2 1/2" single sports exhaust with a sports muffler. Ive just fitted one to my hz prem wagon, real nice, unlocks a bit more performance and economy.
are you looking to undertake the swap yourself, or getting it out sourced? Oh, and try to get the engine and box complete from a hz with the wiring loomfrom the bulkhead connector. makes life a little easier. only other thing you will need is a new v8 accelerator cable, and your set.
Goodluck with it mate, and great to see more likeminded people out there.
Guest (5)
This page was generated in 0.295 seconds.
