bazza30555 Offline
#1 Posted : Wednesday, 30 May 2007 5:28:31 AM(UTC)
bazza30555
did any other hktg's have the same bonnet as the hk gts. (ie. no holes for holden badges) thanks guys.
#2 Posted : Wednesday, 30 May 2007 5:32:49 AM(UTC)
my hk kingswood's bonnet has no holes for a holden badge...come to think of it neither did my previous HT ute or HG van!!!!
maybe you worded your question wrong...?
i'd rather hated for who i am than loved for who i am not.
bazza30555 Offline
#3 Posted : Wednesday, 30 May 2007 5:46:22 AM(UTC)
bazza30555
I have a bonnet which came of a hk sedan that has holden in seperate letters across the front of it. I am after one with out the holes for the pins and the larger holes for the speed nuts on the underside.cheers.
#4 Posted : Wednesday, 30 May 2007 5:52:18 AM(UTC)
do you want holes or not?
if you're near SE QLD i've got one with no holes...
if you want larger holes use a drill...?
hic..sorry, got a few coldies under the belt...hic...
bazza30555 Offline
#5 Posted : Wednesday, 30 May 2007 6:07:41 AM(UTC)
bazza30555
After one with no holes either side but Im in west vic. cheers.
bazza30555 Offline
#6 Posted : Wednesday, 30 May 2007 6:33:16 AM(UTC)
bazza30555
The bonnet I have is possible ht. Are all hk bonnets the same as the hk gts bonnet.
#7 Posted : Wednesday, 30 May 2007 7:00:52 AM(UTC)
The one with H O L D E N across the front is HT.
HG has slots in the underskin on the passenger's side for badge access underneath.
HK has badge on the driver's side lining up with GTS stripes. IIRC not all HK have a badge there, but you can drill the h
bazza30555 Offline
#8 Posted : Wednesday, 30 May 2007 7:29:03 AM(UTC)
bazza30555
Thanks for the info Byron. Cheers John.
#9 Posted : Wednesday, 30 May 2007 4:23:00 PM(UTC)
HK GTS is the same as Kingswood, Monaro, Premier and Brougham in HK. Belmont does not have attaching pins for chrome strip on leading edge
Warren
This page was generated in 0.065 seconds.
