Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
did any other hktg's have the same bonnet as the hk gts. (ie. no holes for holden badges) thanks guys.
my hk kingswood's bonnet has no holes for a holden badge...come to think of it neither did my previous HT ute or HG van!!!! maybe you worded your question wrong...?
--- i'd rather hated for who i am than loved for who i am not.
I have a bonnet which came of a hk sedan that has holden in seperate letters across the front of it. I am after one with out the holes for the pins and the larger holes for the speed nuts on the underside.cheers.
do you want holes or not? if you're near SE QLD i've got one with no holes... if you want larger holes use a drill...? hic..sorry, got a few coldies under the belt...hic...
After one with no holes either side but Im in west vic. cheers.
The bonnet I have is possible ht. Are all hk bonnets the same as the hk gts bonnet.
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
The one with H O L D E N across the front is HT. HG has slots in the underskin on the passenger's side for badge access underneath. HK has badge on the driver's side lining up with GTS stripes. IIRC not all HK have a badge there, but you can drill the h |
Thanks for the info Byron. Cheers John.
HK GTS is the same as Kingswood, Monaro, Premier and Brougham in HK. Belmont does not have attaching pins for chrome strip on leading edge
Warren
