#1 Posted : Thursday, 26 August 2004 7:10:08 PM(UTC)
can any damage be done to a car by accidently starting it with it in gear with no clutch when cold. the car in question is a vx ss
#2 Posted : Thursday, 26 August 2004 9:47:04 PM(UTC)
Only if you run into something.
#3 Posted : Thursday, 26 August 2004 9:58:17 PM(UTC)
You may also lessen the life of your starter motor, but these normaly wear out mechanically before the windings give out anyway. You could conceivably damage flywheel teeth also.
#4 Posted : Friday, 27 August 2004 11:31:52 PM(UTC)
this method of starting the car in gear has come in hand for me a few times, once when i ran out of fuel and the filler neck was 4 inches off the fence, i had to key the car up the driveway to get access to the filler ....
also if your car breaks do
#5 Posted : Monday, 26 September 2005 8:29:45 PM(UTC)
if it was to do any damage they would have a fitment to stop it starting unless the clutch was engaged.
#6 Posted : Tuesday, 27 September 2005 5:30:34 PM(UTC)
VZ`s they do , the motor will not turn over unless the clutch is depressed
#7 Posted : Wednesday, 28 September 2005 3:28:38 AM(UTC)
Hi Cloudy,
Does the motor doing somersaults cheer the clutch up?
Sorry about the attempted humour...Dave
Edited by user Wednesday, 28 September 2005 3:36:35 AM(UTC)  | Reason: Not specified
Taz2 Offline
#8 Posted : Wednesday, 28 September 2005 6:46:09 AM(UTC)
Taz2
2 days of pure rarified air of the Tasmanian high country has starved your brain of oxygen Dave
In thrust we trust
#9 Posted : Wednesday, 28 September 2005 6:50:46 AM(UTC)
Probably right Bruce.... :-))
I'm surprised I didn't get a nose-bleed being up that high. West Australians aren't used to those sort of heights mate.
Cheers...Dave
#10 Posted : Thursday, 29 September 2005 6:09:04 AM(UTC)
just for info, in the army drivers courses, we are taught, that if you stall it going up an offroad bank or hill(steep climb, in 4x4) that you should start it in gear?!?!?
i cringed everytime (as i was the autoelec that got to change all of the broken on
Guest (5)
This page was generated in 0.207 seconds.
