2 Pages<12
madjack Offline
#21 Posted : Thursday, 8 March 2007 8:49:50 AM(UTC)
madjack
Yep,it's the 5th gear I was referring to,OD probably wasn't the right description...so it is internal,the box was a conventional 5spd FWD transaxle with this weirdo electro-pneumatic shifter,a sort of 5th gear bionic arm. Not sure which models it appeared
basketcasebear Offline
#22 Posted : Thursday, 8 March 2007 9:00:31 AM(UTC)
basketcasebear
cant just change diff peter smol,? cause i want really low range as well? for the other thing i want to do with her?
I have had another thought??? [be afraid, be very very afraid]
if you were able to put an electric motor in the middle of the drive t
DOH!!!
madjack Offline
#23 Posted : Friday, 9 March 2007 12:29:35 AM(UTC)
madjack
Hey John
Was that some sort of automatic box on the Hudson Terraplane, a preselector box or something like that?
There's been some interesting stuff built over the years!
MJ
#24 Posted : Friday, 9 March 2007 6:06:12 AM(UTC)
For the early 3spd landcrusers You could buy a pommie made External overdrive.Fairly was the company name.
#25 Posted : Friday, 9 March 2007 6:12:03 AM(UTC)
I just did a dogpile search and came up with this site http://www.faireyoverdrive.com/ now in the US of A And there are other people that do parts for them. It seems they are to suit Landrovers as well. You may be able to find one at a 4wd wreckers.Check
#26 Posted : Friday, 9 March 2007 6:36:58 AM(UTC)
Madjack the strangest thing I have seen was a electricaly operated vacuum controled manual clutch set up on a diahatsu handivan.Oh it had a torque converter that was feed with oil thru the centre of the crank too.
Edited by user Friday, 9 March 2007 6:40:03 AM(UTC)  | Reason: Not specified
#27 Posted : Friday, 9 March 2007 10:22:37 AM(UTC)
yes preselector type. you move the lever and hit the clutch.
Guest (10)
2 Pages<12
