3 Pages<123>
adam PERTH Offline
#21 Posted : Sunday, 19 August 2007 4:59:50 AM(UTC)
adam PERTH
I have never busted a 10 bolt in my life,
i change oil as soon as i get them, how many don't???
i think they are ok up to 400 HP.
A good HK subframe in WA would pull $500 easy. - add that into the wrecking equation of HK prem.
A1 Bogan.
adam PERTH Offline
#22 Posted: : Sunday, 19 August 2007 4:59:50 AM(UTC)
adam PERTH
i change oil as soon as i get them, how many dont???
A1 Bogan.
#23 Posted : Sunday, 19 August 2007 5:44:18 AM(UTC)
Get yourself some more grunt...
Or some more traction..
Crunch, Crumble, Chomp.
ozchevy Offline
#24 Posted : Sunday, 19 August 2007 4:41:57 PM(UTC)
ozchevy
Luke,
Don't take this the wrong way, I know all too well just what a 10 Bolt will put up with.
I don't often brag about this, but 20 plus years ago - I owned and raced a HK Monaro with a Blown 327 small block. The car was putting out in excess of 5
ozchevy Offline
#25 Posted : Sunday, 19 August 2007 4:41:57 PM(UTC)
ozchevy
Luke,
Dont take this the wrong way, I know all too well just what a 10 Bolt will put up with.
I dont often brag about this, but 20 plus years ago - I owned and raced a HK Monaro with a Blown 327 small block. The car was putting out in excess of 500
hg_lover Offline
#26 Posted : Monday, 20 August 2007 7:22:30 AM(UTC)
hg_lover
Well, I did end up finding a chopped 9 inch with a rebuilt 3.5:1 centre so its all good :)
hg_lover Offline
#27 Posted : Monday, 20 August 2007 7:22:30 AM(UTC)
hg_lover
Well, I did end up finding a chopped 9 inch with a rebuilt 3.5:1 centre so it's all good :)
basketcasebear Offline
#28 Posted : Monday, 20 August 2007 7:46:09 AM(UTC)
basketcasebear
So everyone, what is the width of the vn, salisbury, diff and axle? anyone know?
thanks
ptpro
DOH!!!
GEEBEE Offline
#29 Posted : Tuesday, 4 September 2007 10:39:07 PM(UTC)
GEEBEE
Hi Guys,
Presently trying to locate 2 x axles to suit a 10 bolt HT Salisbury V8 diff. Searched most places no luck. The vehicle is presently a variety bash car, however, we would like to carry spare axles. We have been lucky so far not to break any. Don'
GEEBEE Offline
#30 Posted : Tuesday, 4 September 2007 10:39:07 PM(UTC)
GEEBEE
Hi Guys,
Presently trying to locate 2 x axles to suit a 10 bolt HT Salisbury V8 diff. Searched most places no luck. The vehicle is presently a variety bash car, however, we would like to carry spare axles. We have been lucky so far not to break any. Dont
Sandman Offline
#31 Posted : Wednesday, 5 September 2007 3:05:46 AM(UTC)
Sandman
Im with you Luke. 10bolt might be OK for originality, but not for strenght. I used one(against a lot of good advice telling me it wouldnt last) It only did about 7 runs before it screwed an axle off. Gone back to my tried and proven 31spline 9".
Ive had
Sandman Offline
#32 Posted : Wednesday, 5 September 2007 3:05:46 AM(UTC)
Sandman
I'm with you Luke. 10bolt might be OK for originality, but not for strenght. I used one(against a lot of good advice telling me it wouldn't last) It only did about 7 runs before it screwed an axle off. Gone back to my tried and proven 31spline 9".
I've h
adam PERTH Offline
#33 Posted : Wednesday, 5 September 2007 3:09:28 AM(UTC)
adam PERTH
Sandman,
I dont think you will get too many arguements that a 9" is stronger than a 10 bolt.
up to what sort of HP / Torque would YOU rate the sailsbury??
A1 Bogan.
adam PERTH Offline
#34 Posted : Wednesday, 5 September 2007 3:09:28 AM(UTC)
adam PERTH
Sandman,
I don't think you will get too many arguements that a 9" is stronger than a 10 bolt.
A1 Bogan.
Sandman Offline
#35 Posted : Wednesday, 5 September 2007 9:40:48 PM(UTC)
Sandman
I reckon if you were giving a full weight car(HQ-HG etc) a hard time, drag racing etc, that 350 HP would be stretching the friendship.
I sure some people will argue this and I know people have run more HP and got away with it, but I'm talking about reli
Sandman Offline
#36 Posted : Wednesday, 5 September 2007 9:40:48 PM(UTC)
Sandman
I sure some people will argue this and I know people have run more HP and got away with it, but Im talking about relia
#37 Posted : Thursday, 6 September 2007 7:25:03 AM(UTC)
I have seen a few cars smack the wall after an axle breakage as well. Its all over very fast. Normally costing a lot to fix. I have seen a lot of snapped and twisted axles normally it is at the splined end but I have seen 10 bolt axles that were split len
Edited by user Thursday, 6 September 2007 7:27:27 AM(UTC)  | Reason: Not specified
antoni Offline
#38 Posted : Thursday, 6 September 2007 10:32:25 AM(UTC)
antoni
Hi all I think GM made 3 or 4 10 bolts diffs some axles bigger in dia. ring gears are 7 1/2 and 8 1/2 inch dia.
I have a 10 bolt 2.56:1 out of 454 C10 ute.
some may hold up better.
Tony
hg350gts Offline
#39 Posted : Friday, 7 September 2007 2:01:18 AM(UTC)
hg350gts
My 10 bolt when I bought it supposedly had 12 bolt axles in it. Is that a common conversion and would that be a way to make 10 bolts stronger?
#40 Posted : Friday, 7 September 2007 11:51:45 PM(UTC)
i only know of 2. 10 bolt diffs. 1.HK-T-G. the 2ED HQ on. the one tonne has thicker axles. 10 bolt are rated at 4000 ft/lb. DANA 44 is 4400 ft/lb. DANA 60 at 7000 ft/lb. the bango is rubbish, it is a 8 bolt in a salisbury form, with fine spline axles.
Guest (14)
3 Pages<123>
This page was generated in 0.200 seconds.
