#1 Posted : Thursday, 15 March 2007 6:59:47 AM(UTC)
I have a 6 cyl XC Falcon 500 3 speed coloumn auto and I want to convert it to a V8. I found a ZH Fairlane that has a 351 on straight LPG in it and I want to swap everything into my XC sedan as the fairlane body is shot. Is this an easy procedure? Should I also transplant the ZH front suspension/brakes into the XC as well? Does it have different springs? Or should I rebuild the XC front end using aftermarket shocks/springs etc? I want to tighten the handling up as much as I can(within reason and budget).
I'm assuming the ZH has a LSD so I want to put that into the XC too (also has rear disks)...should I swap the brake booster/master cylinder too? or keep my XC one ? The Zh has a C4 I think?, my XC has a FMX ?? I"m assuming all the gear shift stuff will fit as the ZH is also a 3 speed coloumn shift auto ?
What about sway bars ? are they worthwhile ? I'm not going racing..I just want to increase handling and braking performance as much as I can. Can you fit bigger rotors easily ?..do they cost a bucketload? or should I fit the stock brakes front and rear?
How can I tell if the 351 is actually a 351 ? 2v or 4v ? What is better ? Will extractors make a difference ? How do 351's go on gas ? it was converted in 2000 and I'm assuming it has gas heads but I don't know for sure.
What are the "gotchas" in this process if any?
Sorry for all the questions but with the exception of a XL I owned years ago I"ve been a Holden man so am unsure about the Fords.
Thanks for your time!
Paul351xb Offline
#2 Posted : Thursday, 15 March 2007 10:05:55 AM(UTC)
Paul351xb
WOW, just a few questions. LOL. OK I'll give it a shot.
Everything should pretty much swap straight over except the tail shaft. The ZH tailshaft is longer but you might be able to put the unis and yoke on 6 cyl tail shaft and use that. Don't forget
Edited by user Thursday, 15 March 2007 10:13:01 AM(UTC)  | Reason: Not specified
#3 Posted : Thursday, 15 March 2007 8:00:09 PM(UTC)
Wow..thank you so much !
Fuel-line isn't a drama as I'm running straight LPG.
So it'd be best to use the trans out of the ZH? I thought it would be easier as it's all bolted up to the engine already.
I might go buy some aftermarket lowered front sp
#4 Posted : Thursday, 15 March 2007 11:13:02 PM(UTC)
OK I can tell the difference between a BW, C4 or FMX but I buggered if I can think of a way to describe it. You could Google something like "transmission pan gaskets".
As for the BW Vs 9" that's easy. The Borg Warner diff is a Salisbury type with a tin
Paul351xb Offline
#5 Posted : Friday, 16 March 2007 12:30:55 AM(UTC)
Paul351xb
Suspension stuff to check is upper and lower ball joints, idler arm, tie rods, sway bar bushes and saddle bushes.
Stick the car on a hoist and have a look. It's all the same stuff with the 6 cyls and V8s. Prices on replacement stuff vary depending on
#6 Posted : Sunday, 18 March 2007 6:40:09 AM(UTC)
Thanks fellas !!!!!!!!!!!!
cheers!!
Oh, does anyone have a GT Bonnet for sale ?..one with flutes ?
Paul351xb Offline
#7 Posted : Sunday, 18 March 2007 10:08:55 AM(UTC)
Paul351xb
Go with the XC GXL/GS bonnet. XCs never had lock down pins like the XB GT bonnet. Where are you located? They pop up on ebay quite often. You might as well put in a sports dash and get the XC GS/GXL fuel cap. Fairmont/GXL grille and headlights looks
boom Offline
#8 Posted : Tuesday, 20 March 2007 2:54:50 AM(UTC)
boom
How shot is the Fairlane Body? Is it repairable?
Fcuk Psi
#9 Posted : Tuesday, 20 March 2007 5:52:21 AM(UTC)
The body is fine..it's just the right hand front fender and the bumper that's been pushed in.
To fix it you'd need a new fender and a new front clip thing..you know?...the guy who owned it just ran into another car on a wet road after work and banged t
boom Offline
#10 Posted : Tuesday, 20 March 2007 6:19:40 AM(UTC)
boom
would you be willing to sell me the body?
Fcuk Psi
#11 Posted : Tuesday, 20 March 2007 7:02:16 AM(UTC)
**** yeah..... how much you wanna pay ?.....
email me at spazzmo100 at hotmail dot com
boom Offline
#12 Posted : Wednesday, 21 March 2007 12:38:42 AM(UTC)
boom
How much do you want? is the interior in there? which diff is in there?
Fcuk Psi
Guest (13)
This page was generated in 0.226 seconds.
