jayHK69 Offline
#1 Posted : Tuesday, 5 June 2007 9:40:39 PM(UTC)
jayHK69
still looking at options for the 307 rebuild.
any opionins on dart iron eagle ss heads ? 2.02 inlet 1.6 exhaust 67cc chambers 165 runner. 307 will be +60 thou stage 2 or 3 cam.
thanks in advance
#2 Posted : Tuesday, 5 June 2007 10:01:08 PM(UTC)
Valves are too big for a 307 in my opinion. I'd be staying with 1.94"/1.5" maximum.
Sandman Offline
#3 Posted : Friday, 8 June 2007 7:32:11 AM(UTC)
Sandman
Iron Eagles are good heads. 165cc intake should be fine on 307.
Are you going to leave it std, or some hipo mods??
jayHK69 Offline
#4 Posted : Sunday, 10 June 2007 11:16:15 PM(UTC)
jayHK69
sandman, bore out to +60 thou,rebuilt bottom end, stage 3 cam, edelbrock performer intake, hei,th350 with shift kit, 2500 stall, 3.08 lsd, in hk prem.
tossing up between the dart heads & rhs s/r t heads (formerly pro topline heads) both have very similar
Sandman Offline
#5 Posted : Monday, 11 June 2007 6:32:58 AM(UTC)
Sandman
They are both good heads, so I guess go with which one you get the best price on.
What are you planning on for this engine?? Are you just going to use it for a hot streeter? Any racing?? How much is fuel economy an issue?
A stage 3 cam doesn't tell me
jayHK69 Offline
#6 Posted : Monday, 11 June 2007 1:59:53 PM(UTC)
jayHK69
the car is basically going to be a weekend cruiser so economy is too big a deal.
the cam i`m looking at has .442 & .444 lift, duration at .050 is 214 & 224, at 0 is 288 & 298 & lobe centres are 112. hydraulic lifters. after a compression ratio of around
Sandman Offline
#7 Posted : Monday, 11 June 2007 9:55:02 PM(UTC)
Sandman
That should be a pretty good combo, although I'd probably go with the Iron Eagle heads with the smaller chamber for a bit more comression. That will help both fuel economy and HP
jayHK69 Offline
#8 Posted : Tuesday, 12 June 2007 2:07:41 AM(UTC)
jayHK69
sorry sandman that should of said economy isn`t too big a deal.
thanks for your input
Sandman Offline
#9 Posted : Tuesday, 12 June 2007 9:26:16 AM(UTC)
Sandman
Thats OK. I'd still go with the smaller chamber heads for the HP anyway. 10-1 CR will run around no worries. Should be a stout combo.
The only other thing I would add is a good ignition. A crane Hi6 or an MSD 6AL with the coils to go with them. My prefer
jayHK69 Offline
#10 Posted : Tuesday, 12 June 2007 9:47:26 PM(UTC)
jayHK69
have a msd streetfire dizzy to go in it & already have electric fan set up on it. how would you suggest getting cold air in ?
you`ll have to clue me in on the under drive pulley, that`s a new one to me
Sandman Offline
#11 Posted : Wednesday, 13 June 2007 8:01:04 AM(UTC)
Sandman
The cold air can be done a few ways.
Most common is a bonnet scoop, and hole in the bonnet with the air cleaner sealed to the bonnet from underneath so that the only air is sucked from outside the car.
Or. You can use a factory kind air cleaner and mod
