#1 Posted : Friday, 23 March 2007 8:18:52 PM(UTC)
Hello
I have a 2001 TS Astra and the air conditioner does not work at all. The car has only done 33,000 km and been regularly serviced. I took it to Suttons Waitara who charged $80 to tell me it needed a new compressor, condensor, O rings and a regass - total cost $1975. Needless to say I thought I would investigate this further.
After reading this forum (thanks to Dr Terry) and other car forums I understand the TS Astra has a common problem with the clutch coil on the compressor.
Can experts out there (Dr Terry) explain how and why the clutch coil burns out and if replacement coils are free of the initial problem. Is there a simple diagnostic check for this fault, hence avoiding the costly relacement of parts as recommended by Holden? Anyone recommend a reliable honest a/c workshop in the Hornsby area of Sydney?
Many thanks for any advice.
Edited by user Friday, 23 March 2007 8:43:23 PM(UTC)  | Reason: Not specified
#2 Posted : Thursday, 8 May 2008 10:37:16 AM(UTC)
Hi Guys,
I had a similar problem with my Astra TS compressor and Holden wanted $750 to fix (I guess replace the clutch). When I took it to an "honest" AC specialist he told me (before he even lifted the bonnet) that the clutch has a temp. cut out diode w
#3 Posted : Saturday, 10 May 2008 2:51:58 AM(UTC)
will be the compressor clutch coil,i just used a repaired one from somewhere.
degas the system remover compressor replace cluct refit compressor,regas.
it,s ok for me as a mechanic have access to the gear to do it.
look around dont pay big buck,s for a
Guest (5)
