What type of diffs do 6cyl UC Sunbirds Torana's have?? Are they stronger than the banjos in LH toranas? If so, Will the fit an LH?? I was told the floorpan and trailing arms are different.
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
Baby Salisbury diffs. Same as 4,6 and 253 Commodores and 6cyl WB's. All UC's are the same, just that Sunbirds have 3.9:1 gearing and normally have coarse spline axles. The crownwheel and pinion are the same as a banjo, as are the axles. They are essential |
Thanks Byron. Kinda what i figured. Was just looking for a cheap, easy way out to get rid of the banjo in the 253 LH I bought for the missus. She's keen to take it to the drags, but I reember what banjos were like when I was a kid and had an EH. Never ha
Check a 1970's Volvo diff for width. Same stud pattern, and disc brakes too.
Thanks for the suggestion Byron, but afraid i couldn't do that on principle. While I relent and run 9" ford diffs, thats the only non GM stuff I have, everything else is Holden and Chev. My missus has a ford, which I tell her it shows how much I care
byron,ive never seen a 3.9 in a uc in anything but fine spline...pulled 3 out of housings in uc sunbirds on thursday and sold them..all fine splines.been selling the 3.9 ratios out of uc sunbirds for years.always been fine splines..maybe im just lucky? |
Byron , I was re-reading your first message. Are the upper mounts on a large salsbury the same as a UC. If so, it would be nearly worth just putting a UC rear floorplan in the LH perhaps. Then I could use the UC diff, and if it isn't strong enough, it wou
They are just banjo internals in a small salisbury housing. Maybe it's because the Commodore ones are all fine spline, like V8 Toranas? If that's the case just run a fine spline banjo with UC axles (or V8 LH/LX axles). What you describe with the rear flo |
