memryz Offline
#1 Posted : Sunday, 25 March 2007 5:41:52 AM(UTC)
memryz
Hi Guys, Its time for a motor for mums HR, I would like to use an injected 6 cyl and auto so that it is easy for my wife to drive and reasonably economical.
My first thought was a commy V6, but can anyone tell me anything about the VK injected motor, or the VL RB30.
To save heaps of modifying which would be the better one to use, and what auto options do I have, because I wouldnt mind any overdrive if it was possible...
Also can anyone tell me if there's much weight difference between the two. any help would be appreciated.
peter_flane Offline
#2 Posted : Sunday, 25 March 2007 6:29:43 AM(UTC)
peter_flane
The VK injected motor will bolt straight into a HR, no major mods needed at all.
You can even put the head and injection of the VK injected motor on the HR motor with some small mods.
If you are getting someone else to do all the wiring mods for inj
#3 Posted : Sunday, 25 March 2007 6:38:18 AM(UTC)
If you can do the vast majority of the conversion yourself, an RB30 and JATCO auto are a good swap. I'd think the T700 auto on the back of a V6 would be a bit big for the HR Trans tunnel, but I haven't done it so can't be positive.
As Peter said above,
peter_flane Offline
#4 Posted : Sunday, 25 March 2007 6:42:42 AM(UTC)
peter_flane
Actually when you start talking auto as well, it wont really cost any more to fit a Trimatic as fitted to the VK behind the VK motor, but no overdrive.
If you were to fit the Commodore V6, you could have a 4 speed auto with overdrive. With the V6 you w
memryz Offline
#5 Posted : Monday, 26 March 2007 12:02:31 AM(UTC)
memryz
thanks guys, I will be doing most of the conversion myself, and farm out what I cant do.
So of the two straight sixes which is the better motor. The Vk sounds good and easy, is the VL motor much harder to do, and is it a better choice,
Dave I will s
#6 Posted : Monday, 26 March 2007 5:46:30 AM(UTC)
the vl is a lot more powerful and economical but is also a lot more expensive for parts and harder to service yourself.
I don't know where the prices mentioned above come from. You can pick up a complete VK Calais injected car for less than $500, you are
peter_flane Offline
#7 Posted : Monday, 26 March 2007 5:54:53 AM(UTC)
peter_flane
The trimatic as fitted to the original VK injected 6 had the same clutchpacks as the 253 Trimatic. The EH Limo www.ehlimo.com.au has an original 186 block with VK head, injection and auto fitted to make similar to original VK inj power and torque. I would
#8 Posted : Monday, 26 March 2007 7:02:32 AM(UTC)
I found the economy about 2 or 3mpg more with the injected motor, but power was considerably more.
You can use the injectors you get with the injected motors, they are stainless steel and quite good.
I forgot to mention that if you just fit the VK motor
#9 Posted : Monday, 26 March 2007 7:14:59 AM(UTC)
Hi Rex,
I'll send that information across later tonight or tomorrow.
Cheers...Dave
memryz Offline
#10 Posted : Tuesday, 27 March 2007 5:03:31 AM(UTC)
memryz
thanks for all the tips guys,couple more q's... besides the engine no. thing what is the benifit of using say a 186 block rather than the whole VK six. Emission control and engineers reports are pretty easy ouer here, so that dont really factor into it.
peter_flane Offline
#11 Posted : Tuesday, 27 March 2007 8:23:23 AM(UTC)
peter_flane
Weights are the same. The block is virtually the same. You can build the same motor. No emmissions required in Victoria if using a pre 1976 block.
This page was generated in 0.118 seconds.
