#1 Posted : Thursday, 7 June 2007 9:53:15 PM(UTC)
Hi all, Had a question about the diff on my HZ Premier - 253 with a trimatic, 10 bolt Salisbury. I use this as a daily drive in peak hour traffic - when slowly crawling along (usually on a downhill run) it makes a big clunk when changing gears. My foot is on the brake, and noticed when its just about to change if I give it a bit of accelerator it seems better. It seems to come from the passenger side as well.
Not sure if this was a feature back then, but just wanted to check and see if this was a sign of something needing work / replacing. I've had the diff serviced about a year ago with all new wheel bearings.
Any help would be greatly appreciated...
ozjason Offline
#2 Posted : Friday, 8 June 2007 3:55:03 AM(UTC)
ozjason
Dont have dodgy Unis, do you? Get under the car while parked and try to move the drive shaft... Should be able to see any slack in the universals.
Jason.
ozjason Offline
#3 Posted : Friday, 8 June 2007 3:55:03 AM(UTC)
ozjason
Don't have dodgy Uni's, do you? Get under the car while parked and try to move the drive shaft... Should be able to see any slack in the universals.
Jason.
camlj Offline
#4 Posted : Monday, 11 June 2007 11:08:30 PM(UTC)
camlj
hey mate i had the exact same problem with my lj. changed the diff centre and set up the backlash correctly and put in new uni's and it still did it after that. i only just sold the car the other week and the guy who bought it said it was something to do
camlj Offline
#5 Posted : Monday, 11 June 2007 11:08:30 PM(UTC)
camlj
hey mate i had the exact same problem with my lj. changed the diff centre and set up the backlash correctly and put in new unis and it still did it after that. i only just sold the car the other week and the guy who bought it said it was something to do w
#6 Posted : Tuesday, 25 September 2007 10:56:35 PM(UTC)
My wb Does this as well
#7 Posted : Wednesday, 26 September 2007 1:47:30 AM(UTC)
my hq does it as well just replaced both unis the diff centre i just put in had almost no back lash but sounds like it has play of an inch or more its definitly coming from the diff centre i will have to get another one built
This page was generated in 0.066 seconds.
