jayHK69 Offline
#1 Posted : Friday, 30 March 2007 3:05:03 AM(UTC)
jayHK69
have just installed performer intake & reco quady on the 307 & it wont idle properly. when driving it`s fine & has plenty of power when i hit the go fast peddle.
at idle the revs drop off then come back up again, i was thinking maybey it`s sucking air some where, gasket not sealing right?
any help would be greatly appreciated.
jabba Offline
#2 Posted : Friday, 30 March 2007 4:03:50 AM(UTC)
jabba
If it is sucking air past the gaskets, you will know it. There is a shrill, screaming whistling noise (scared the cr*p out of me, thought it was grinding something.
One thing that I always had trouble with was the PCV's not sealing at idle properly (wen
#3 Posted : Friday, 30 March 2007 9:32:13 AM(UTC)
Have you done a base idle and mixture adj since you fitted it all.If so how many turns out are the idle mixture screws.
jayHK69 Offline
#4 Posted : Saturday, 31 March 2007 12:48:17 AM(UTC)
jayHK69
hg ss, have adjusted mixture screws out 1.5 turns each, pvc is working fine. thanks
tanart Offline
#5 Posted : Saturday, 31 March 2007 1:42:54 AM(UTC)
tanart
by default the idle screws need to be turned out 2 turns. Put the idle up slightly until you have some idle and then turn the air screws out until you hear the motor running smoother and faster. Once done bring the idle down via the idle screw then check
jayHK69 Offline
#6 Posted : Saturday, 31 March 2007 7:54:21 AM(UTC)
jayHK69
thanks tanart i`ll give it a go in the morning
#7 Posted : Saturday, 31 March 2007 8:50:53 PM(UTC)
The actual base idle adjust setting on a Qjet is 3 to 4 turns out.If you are only 1.5 turns out I doubt you have a vac leak.Tanarts description will get you set up about right anyway.You may just have to adjust the mixtures and base idle settings down a c
Edited by user Sunday, 1 April 2007 7:46:32 AM(UTC)  | Reason: Not specified
This page was generated in 0.080 seconds.
