Handgunner Offline
#1 Posted : Friday, 30 March 2007 8:07:34 AM(UTC)
Handgunner
Hi everyone, on the way home tonight my landi converter froze up and the car stopped ( 186 Prem).. first tried removing the thermostat..no joy..drove for 10 minutes then Froze again.. its worked well for 30 odd Thousand Kays.. i am thinking its full of goop ! Can someone suggest a way to clean this and anything else i need to do..( New Gaskets /Seals Etc ) i have read somewhere that a clean may fix the converter...
I aint rich and prefer to spend my money on other toys..
Is this a straightforward job ?
I have also read that Antifreeze should be used with a converter..Whoops...have NOT been using that..and also it should be mounted below or level with the heads ..Better Flow to converter....
Thanks a lot Guys and Gals....
Hope to fix this little sucker soon !
Bang Bang
Bang Bang
hairy-dude Offline
#2 Posted : Friday, 30 March 2007 8:40:05 AM(UTC)
hairy-dude
Have you tried flushing the water hoses? There may be a blockage in a hose. My VH is on gas and its converter is connected with tee-pieces in the heater hoses. If your setup is like that, the water hoses may need a good flush out. If no water gets to the
#3 Posted : Friday, 30 March 2007 9:16:09 AM(UTC)
Hi there, yes i flushed out the hoses and they are clear and flow ok( when not frozen )i even ran the hoses directly from the water pump and bypassed the heater hoses..still Froze up !
Lucky for me i have a very good friend who came out after work wit
#4 Posted : Friday, 30 March 2007 10:56:24 AM(UTC)
When you flushed the convertor, did you bleed the water gallery in it to make sure there isn't an air bubble?
It might be time to go to a radiator shop and have your cooling system pressure reverse flushed.
Cheers...Dave
BrianH Offline
#5 Posted : Friday, 30 March 2007 7:58:33 PM(UTC)
BrianH
While you were flushing the hoses, was there a good flow of water through the converter? A converter will not freeze with hot water in it so you either have a restriction inside the converter that is preventing adequate water flow or hot water is not ge
Edited by user Friday, 30 March 2007 8:01:11 PM(UTC)  | Reason: Not specified
Handgunner Offline
#6 Posted : Friday, 30 March 2007 9:52:41 PM(UTC)
Handgunner
Thanks Brian..that info is awesome ! I am now going to thoroughly disassemble the water [pump /housing and clean it all up...
Just got some antifreeze too !
With the converter, is it easy to clean its water galleries?
Thank you very much..
Bang Ban
Bang Bang
Rhys Offline
#7 Posted : Friday, 30 March 2007 11:17:55 PM(UTC)
Rhys
I've had a converter freeze up before due to an air lock as Dave suggested. I always thought it was better to mount the converter below the top of the radiator so there is less chances of getting air locks in the converter.
Also while you're reverse fl
Handgunner Offline
#8 Posted : Saturday, 31 March 2007 4:03:23 AM(UTC)
Handgunner
Back on the road... :)
Thanks a lot fellas... i have changed the water pump for a new one ( Already had one ) got a new thermostat, flushed out all cooling systems...heater , converter block etc..( not too much rust / gunk )
and refilled with water...
Bang Bang
