#1 Posted : Saturday, 7 April 2007 7:03:54 AM(UTC)
Hi I'm considering buying a 79 HZ premier sedan.Could someone explain the codes I've been provided with.HZ8WN69 466907A.
Thanks Jenny
#2 Posted : Saturday, 7 April 2007 10:16:23 AM(UTC)
Hi Jen, the codes don't look familiar to me. The first resembles a chassis number and the second maybe an engine number, but neither of them are complete.
Ask the seller to send you the VIN number, which will be 14 alphanumeric digits on a long skinny ta
Munromad2004 Offline
#3 Posted : Saturday, 7 April 2007 7:42:14 PM(UTC)
Munromad2004
The first code is the model code for a HZ Kingswood. The second is a build/body number and the A on the end means it was built in Adelaide.
A HZ Premier would be HZ8WP69 (not all factories included the W though so 8N69 is Kingswood and 8P69 is Premie
#4 Posted : Saturday, 7 April 2007 10:25:28 PM(UTC)
These are the first two lines on the body ID plate, the VIN would be 8N69**L466907Z
Yes it is a Kingswood.
Warren
#5 Posted : Sunday, 8 April 2007 6:56:13 AM(UTC)
THANKS FOR CONFIRMING MY SUSPICIONS IT WAS A KINGSWOOD AND NOT A PREM AS ADVERTISED.CHEERS JENNY
#6 Posted : Wednesday, 11 April 2007 2:51:41 AM(UTC)
does any one know if you can fix a clock out of a gts dash its a HZ yellow needle and all the other guages are fairly accurate it just wont work at all is there any way of testing it?
