peterwmh Offline
#1 Posted : Monday, 11 June 2007 5:37:41 AM(UTC)
peterwmh
Hi all,
Looking at buying a 1978 HZ Statesman, just wondering if the engine number 11qt939584 could be the original motor, any help appreciated.
Peter
JBM Offline
#2 Posted : Monday, 11 June 2007 5:56:04 AM(UTC)
JBM
11QT is the correct engine number prefix for an early HZ Statesman. Check the cast date above the oil pump, should be like 2F8, to see if it is before or close to the cars build date.
If you're not sure how to check the cast date look at this: http://w
peterwmh Offline
#3 Posted : Tuesday, 12 June 2007 9:22:26 PM(UTC)
peterwmh
Thanks for the reply. Regards peter
peterwmh Offline
#4 Posted : Wednesday, 20 June 2007 6:46:11 AM(UTC)
peterwmh
Well I bought the car, yep the engine is original for that car, so much so that the original sale document confirms it still runs the engine it left the factory with! Happy about that.
Peter
