#1 Posted : Thursday, 12 April 2007 10:31:12 PM(UTC)
Using a kill switch with a Bosch MEC 717 Electronic Transformer ignition coil in a 79 XD Falcon causes these type of coils to break down. If your Falcon is not computer managed how have you made it thief proof ? or what have you done to prevent it from being stolen ??
6pak Offline
#2 Posted : Friday, 13 April 2007 7:54:53 AM(UTC)
6pak
My brother in law has a battery isolator switch mounted into the bulkhead behind the drivers seat. he keeps the red plastic key on his keyring with the regular key and has a quick disconnect fitting so he can detatch it, plug it in to get the current flo
Dmax Offline
#3 Posted : Friday, 13 April 2007 8:31:40 AM(UTC)
Dmax
I had one car that had a hidden switch that you had to hold down while turning the car over, which was a latching relay to the fuel pump. The switch was inside the gear **** boot so no one knew it was there. Just push down on the corner of the boot when
648hp Tunnel Rammed 351, It does not get any better
BrianH Offline
#4 Posted : Monday, 16 April 2007 7:06:59 AM(UTC)
BrianH
There are plenty of effective electronic devices but I think these should be combined with something highly visable. It is not much fun having your car saved by a concealed switch after the thief has already broken a window and smashed the steering lock
#5 Posted : Tuesday, 17 April 2007 9:51:20 PM(UTC)
Thank yopu all for your valuable suggestions
sly376 Offline
#6 Posted : Thursday, 19 April 2007 8:02:04 AM(UTC)
sly376
You can make up a simple kill switch by hooking it up to your ignition system. Or you can just take off your coil lead or rotor button she won't fire up without that :)
