hey all,,any one know whether body filler will stick to aluminium?? thanks already
ptpro |
more than basketcase than a bear! DOH!!! |
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
Ask a Landrover owner, or a panel beater specialising in them.
I don't know for sure, but I have seen Landrovers with bog in them so I assume the answer is yes. Cheers...Dave Edited by user Monday, 16 April 2007 5:47:14 AM(UTC)
| Reason: Not specified
It will stick to aluminium if it is freshly sanded. If the aluminium has been exposed before filling, you need to sand it and then clean with methylated spirits. Ideally if restoring there is another process that involves an etch primer and then an epoxy |
thanks peter, that was great.
ptpro |
I've boged up 100 s of aluminium panels ( new Mercedes front guards , Audi , Landrover and never used etch primer first or metho . Never had a problem & have been a Panelbeater for 21 years . Sand with 36 grit first then blow off with blower till dust fr
We use metho as any moisture remaining in the scratches of an aluminium panel are able to cause problems. In saying that, there is no real reason that there should be any moisture on any panel, wax/ grease remover will clean it pretty good, it is just one |
hi adding to this would the aluminium expand and srink with heat causing bog-filler to lift as much as steal
No significant difference to steel expansion rates at the temperatures a vehicle is subjected to. |
hey thanks y,all, you have just turned me into a panel beater extroadinaire.!! cheers
ptpro |
