Micko Offline
#1 Posted : Wednesday, 18 April 2007 7:55:06 PM(UTC)
Micko
Ive had to relist this topic, as I really need some feedback on this problem I am having... I own a VT Series 2 1999 calais. After every heavy down pour (thanks for the rain Lord) under my feet fills up with water. I know this because the previous owner has cut the carpet, from the pedals to the drivers seat. Enough to be able to stick your hand in and feel quite a large pool of water. By the next day it smells like a dirty wet dogs towel. I can't work out where this water is coming from. Is this a common problem is there something i dont know? Please any thoughts would be helpful. Thanks all... Micko.
#2 Posted : Wednesday, 18 April 2007 8:10:59 PM(UTC)
Could it be like the HQ-HZ when the plenum fill full of leaves and junk and it blocks the drain hole the water ends up at your feet, you might have to pop your bonnet and see if you can remove the plastic cover and see if theres a build up of dirt and stu
Holdenute Offline
#3 Posted : Thursday, 19 April 2007 12:38:41 AM(UTC)
Holdenute
More than likely will be water running along a cable or wiring. If the cable is higher on the outside than on the inside, then the water will follow it along. Check speedo cables, clutch cables, radio antenna cable (this was my issue) and also check the g
Never late in a V8
Micko Offline
#4 Posted : Thursday, 19 April 2007 10:06:43 AM(UTC)
Micko
Thanks guys. Im taking it all in...
Mick.
shouldntastarted Offline
#5 Posted : Friday, 20 April 2007 8:24:20 AM(UTC)
shouldntastarted
Could also be a poorly sealed windscreen. As these things are pretty much glued in there is scope for a bad seal
The mind is like a parachute! It works far better when open!
BrianH Offline
#6 Posted : Friday, 20 April 2007 10:23:41 AM(UTC)
BrianH
Micko
Years ago when I worked for a few new car dealers, water leaks were a common complaint. We used to get someone inside the car and an apprentice outside with a hose. He would keep squirting the water in every possible place until we could see w
#7 Posted : Friday, 20 April 2007 4:25:08 PM(UTC)
I used to work at holdens in the water test inspection area, on the vn`s we had a lot of cockpit/firewall leaks this is where the complete dash system/firewall area meets the body and is sealed. If the area was not sealed usually in the plenum area the ca
