#1 Posted : Monday, 30 April 2007 10:16:35 PM(UTC)
I'm in the processes of installing a cleveland 302 from an XD into a 66 XR Falcon.
The 302 is running a Carter thermo quad with all the emissions gear, automatic choke etc.
Does anyone know if I ditch all of the emissions gear can I still run the thermo quad.
I'm in Victoria and thanks in advance for any assistance.
Paul351xb Offline
#2 Posted : Tuesday, 1 May 2007 1:24:13 AM(UTC)
Paul351xb
Yep you can still run it. There is a trick to it from memory. I remember the mechanic blocking something off when we were running the thermoquad on my car. Lotta years ago and the memory is getting kinda swiss cheesy with age but yes you can run the th
#3 Posted : Tuesday, 1 May 2007 2:21:50 AM(UTC)
Thanks for that, I was hoping that was the case.
With respects to blocking bits off, I suspect it might have been what they are calling the EGR Plate that feeds exhaust gases back into the manifold and other bits and pieces.
Is there any issues with
Paul351xb Offline
#4 Posted : Tuesday, 1 May 2007 4:53:07 AM(UTC)
Paul351xb
Yeah I think that's the thing he blocked. I'm not sure what you have to go through in Vic. Worst comes to worst, have the pollution crap there when you register it.
You can either have it hanging there as decorative non functioning or you can just rip
Dmax Offline
#5 Posted : Tuesday, 1 May 2007 5:41:37 AM(UTC)
Dmax
The autochoke works by transfering heat from the exhaust to a heat sensitive switch which turns on, then an eletrically operated switch slowly opens the secondries.
If you take off the heater tube from the exhaust to the autochoke, the secondries will
Edited by user Tuesday, 1 May 2007 5:59:27 AM(UTC)  | Reason: Not specified
648hp Tunnel Rammed 351, It does not get any better
Paul351xb Offline
#6 Posted : Wednesday, 2 May 2007 1:23:44 AM(UTC)
Paul351xb
My choke was disabled but the secondaries still worked kinda sorta. you mean THAT'S WHY my thermoquad didn't behave properly? DMAX, Where were you when I needed you?
Dmax Offline
#7 Posted : Wednesday, 2 May 2007 7:21:02 AM(UTC)
Dmax
Yeah, when I put pacemakers on a P6 LTD of mine, I had the problem of the secondries not opening as well. The choke closes off the back two barrels which is where the secondries are, so when the choke never opens up (ie turns off) airflow is restricted p
#8 Posted : Wednesday, 2 May 2007 7:26:57 AM(UTC)
Thanks for that guys,
After fiddling with it little over the weekend I was half thinking about setting up an old school manual choke, but i might try Dmax's suggestion first!
Dmax Offline
#9 Posted : Thursday, 3 May 2007 7:06:54 AM(UTC)
Dmax
The auto coke setup works really well on the thermoquads, so I would stick with it myself.
This page was generated in 0.134 seconds.
