edelbrock1 Offline
#1 Posted : Sunday, 17 June 2007 1:36:02 AM(UTC)
edelbrock1
Hi guys,
I have heard that early toyota power steering units can be adapted to suit HK - HG's. I have even seen a pic of one operating.
So I went out and bought a powersteer box from a toyota. But from what I can see, there is no way in hell that it will even go close to fitting.
Has anyone done this conversion or know ANYTHING about it?? maybe you know someone that has... ANY help would be awesome..
peter_flane Offline
#2 Posted : Sunday, 17 June 2007 5:43:21 AM(UTC)
peter_flane
We fitted one to the EH Limo. The chassis rail had to be modified by me, the steering arm had to be resplined to Toyota by a toolmaker friend, the column remade to be collapsible by a fitter/ turner friend, and the whole lot approved by the engineer. Cert
hz dude Offline
#3 Posted : Sunday, 17 June 2007 6:42:24 AM(UTC)
hz dude
If u dont mind me asking [peter smol] what kind of toyota steer box was it and was an expensive ordeal? just like too know for my mind in times to came maybe thanx
it's beer o'clock
peter_flane Offline
#4 Posted : Sunday, 17 June 2007 9:25:54 AM(UTC)
peter_flane
It is power steer box off a Toyota MX 62 Cressida. There may be similar models.
I would plan on a cost of about $3000 to get it done and engineered right to work right. The box itself was $50 from a wrecker.
edelbrock1 Offline
#5 Posted : Sunday, 17 June 2007 7:39:52 PM(UTC)
edelbrock1
Thanks Peter. I am certainly not going to spend that kind of money. All I have to go on is this picture. (I will try and attach it to this post) I did hear that the Toyota pitman arm bolts directly to the Holden steering gear and that 2 bolts for the
#6 Posted : Monday, 18 June 2007 2:24:25 AM(UTC)
I have heard the same thing about an early Toyota that has the same steering box as a HK-G but it is power instead of manual and it is virtually a straight fit.
peter_flane Offline
#7 Posted : Monday, 18 June 2007 4:46:53 AM(UTC)
peter_flane
I don't want anyone to take this as a personal thing, but 'heard' does not cut it. How many of these conversions have you done? How many have you seen? It is not 'virtually a straight fit'
edelbrock1 Offline
#8 Posted : Monday, 18 June 2007 7:27:00 AM(UTC)
edelbrock1
That is exactly why I am here asking questions. I have only heard about this conversion and have 1 photo of it. I 'heard' it was reasonably straight forward so I am just here to find out if that is actually correct.
Obviously it isnt.. but it sure kil
Tom Slick Offline
#9 Posted : Monday, 18 June 2007 8:40:15 PM(UTC)
Tom Slick
G'day,
SOOOOO, is there anyone out there on this topic who has done it with the earlier model toyota where it was a bolt-on, easier and cheaper affair? Its a pity that the conversion that Peter Smol has done is such an expensive exercise. Power steeri
Don't eat the yellow snow
#10 Posted : Tuesday, 19 June 2007 12:22:13 AM(UTC)
Would DrTerry or Warren know what number of hktg's were sold with factory powersteer? And how much would you expect to pay to get powersteer setup recoed and fitted?
HkDave
peter_flane Offline
#11 Posted : Tuesday, 19 June 2007 4:24:36 AM(UTC)
peter_flane
We had to have power steer fitted to the EH Limo as part of the engineering. We had two choices.
Original EH power steer which was not necessarily the best of units, and not easy to come by or recondition.
Or adapt some other type of power steering
#12 Posted : Tuesday, 19 June 2007 4:52:21 AM(UTC)
I am sure it was Warren Turnbull who mentioned about the Toyota powersteering box on this site about two years back. Just because you have done it does not mean you have done it the best way the easiest way or the cheapest way. More heads make up a good i
peter_flane Offline
#13 Posted : Tuesday, 19 June 2007 6:07:48 AM(UTC)
peter_flane
TD I agree, you are absolutely correct.
#14 Posted : Tuesday, 19 June 2007 6:49:02 AM(UTC)
Factory steer on HK-HG was a ram setup like an EH. The ram is in parallel to the normal steering. There are two basic different setups - one for the Chev engines and one for the Holden 6 and V8 engines, the difference is in the bracket that attaches the r
#15 Posted : Tuesday, 19 June 2007 7:06:50 AM(UTC)
I first saw it on an HR, where he used a Toyota box and then a HK. I asked about the HK and the owner stated "he only drilled an extra hole in the side of the box and it fitted" I then saw a guy at Wangeratta and again at Bathurst with it fitted to a GTS
edelbrock1 Offline
#16 Posted : Tuesday, 19 June 2007 8:42:19 AM(UTC)
edelbrock1
Hmmm well this could possibly all make sense. After all, the EH steering box would be a totally different beast with different mounting holes to the HK T G one. Back to the drawing board on this one. Need to find that fella with it in his 327.
chee
This page was generated in 0.145 seconds.
