#1 Posted : Saturday, 12 May 2007 4:51:26 AM(UTC)
Howdy,
Sitting here contemplaiting the ute's destiny & was wondering - Can you take a 308 past 60 thou? Here's the reason: I have a 308 aussie pattern which a mate & I put new bearings & rings in [bores honed only - are they supposed to be egg shaped:)?].
However we stuffed up with the cam & the motor ate it. The heads are a different story, I've spent $1000 bucks on the heads with porting new valves & everything, & the whole lot probably wouldn't get $500 on ebay. She didn't blow much smoke after the first day & seemed to run ok except for the cam chewing noises.
So I was thinking about building the bottom of the motor to the same quality of the heads.
This is where my dielema comes in- do I just repair the cam & replace the cam bearing (which means pulling the motor down again anyway) or do I go the whole hog & have the pots bored & honed which means 80 thou plus new pistons etc etc.
The cooling system is a brand new large radiator (standard 308 HQ I beleive), clutch fan & water pump. The build for the 308 will be (if done) for gas as a cruzer with a bit of a lump in the cam, to make the chicks look.
If I go that far I may as well get a turbo block & put a TH700 behind it so I get some reasonable economy! Which leads into my next thought - there's no reason I can't put the aussie internals in a turbo patterned block, is there? Maybe I should just save my pennies & get a blue 308 bottom end - but I've already spend money on the new rings & bearings in this one. Then of course there's the lure of just putting a toyota blower on the 186.....
Sometimes you just shouldn't think too much hey!?
The Beige Hornet.
Munromad2004 Offline
#2 Posted : Saturday, 12 May 2007 7:47:08 AM(UTC)
Munromad2004
You could always get the block sleeved. They are getting rare and it's better than dumping it for scrap.
If you're not going to be making mega horsepower it will be absolutely fine.
#3 Posted : Saturday, 12 May 2007 5:38:48 PM(UTC)
Had an epiphany last night - you can redrill a block to turbo pattern can't you?
The Beige Hornet.
#4 Posted : Saturday, 12 May 2007 6:22:22 PM(UTC)
As long as it's a HJ or later block you can. Early blocks (when they were all 4spd or trimatic) are a different casting and don't have the metal there to be drilleed and tapped.
You can take them 80 thou - seen plenty. But if they have any corrosion you
#5 Posted : Sunday, 13 May 2007 5:36:59 PM(UTC)
Ta heaps. Probably better to play with TH blocks now & keep the aussie block for posterity.
The Beige Hornet.
ED57FE Offline
#6 Posted : Tuesday, 15 May 2007 12:02:54 AM(UTC)
ED57FE
ive got a 60 thou out turbo block with good crank etc.
i was going to throw it out, but you're welcome to it.
th engine numbers are missing . milled off, so will need to put your numbers on it.
im in sydney if anybody is interested.
#7 Posted : Tuesday, 15 May 2007 1:14:46 AM(UTC)
ED57FE: ta, but you're a bit far away, I'm near Brissie!
The Beige Hornet.
dca1042 Offline
#8 Posted : Thursday, 17 May 2007 5:56:01 PM(UTC)
dca1042
beige hornet,have th pattern 308 would suit you to the t.only 40 in bore. large valve heads,213@50cam,allfresh.new intake also.flexplate included.$1900 ono.plus freight.call 0428566683 or post back here,cheers dave.
#9 Posted : Thursday, 17 May 2007 6:15:33 PM(UTC)
Thanks dca1042 but have decided to go the road less travelled & build something different - cheers!
The Beige Hornet.
dca1042 Offline
#10 Posted : Friday, 18 May 2007 8:18:25 PM(UTC)
dca1042
just offering my services cheers dave
Guest (5)
