#1 Posted : Saturday, 12 May 2007 7:08:21 AM(UTC)
Hello all,
I have a VU series 2 ute and my frontbar got damaged recently. I have been considering having a bodykit put on and now seems like a good time to do it... but i have a few questions that i hope someone here can answer..
1. is it easy/hard/possible to change the headlights on my VU to the more recent headlight models found on VYs etc?
I ask this because many of the bodykits (frontbar in particular) require the newer style headlights to fit.
2. will a newer model bodykit (like the SSX one found at http://www.capa.com.au/accessories_kits.htm) fit properly to my VU with the original VU brackets?
I hope i haven't confused anyone. Any help would be appreciated, and if anyone has any suggestions for which bodykit to go for, feel free to let me know your thoughts!
#2 Posted : Saturday, 12 May 2007 9:06:08 PM(UTC)
Only VT, VX & VU lights will fit (with matching bar & grille).
VX Berlina, Calais & HSV had different lights to the VX & VU - without the teardrop, and only require the matching bar & grille from a Calais, Berlina or HSV(VX Clubby, Senator etc)
If y
#3 Posted : Saturday, 12 May 2007 11:33:33 PM(UTC)
ok thanks for the information, it has helped a lot so far.
But it leads me to another question..
would the vx clubsport frontbar fit on my vu? they both have the teardrop headlights right? am i missing something here?
Sorry if I seem uninformed about t
#4 Posted : Sunday, 13 May 2007 3:32:08 AM(UTC)
I think the VX Clubsport uses Berlina headlights, like a VX GTS.
#5 Posted : Sunday, 13 May 2007 6:11:09 AM(UTC)
That's correct Byron, they do use the Berlina/Calais lights, so you'll need to change your headlights.
They don't have the teardrop on them, and the inner edge against the grille is a sharp edge - like a VY headlight.
Here's what a VX Calais looks lik
Edited by user Sunday, 13 May 2007 6:12:14 AM(UTC)  | Reason: Not specified
#6 Posted : Monday, 14 May 2007 2:15:23 AM(UTC)
thanks everyone.
that last picture you posted commodorenut is the one I saw.. I guess I will probably look into that aftermarket one. Is there anything I should watch out for when buying this?
#7 Posted : Monday, 14 May 2007 8:13:14 AM(UTC)
Make sure it's a good fit, and sufficiently attached to the reo to prevent is from flopping about, causing fatigue cracks.
A lot of people aim to achieve nothing in lif
Guest (5)
This page was generated in 0.066 seconds.
