peterwmh Offline
#1 Posted : Wednesday, 20 June 2007 7:53:42 AM(UTC)
peterwmh
Hi all,
Always the way when you buy a 'new' car there's going to be a few surprises! Was looking under my HZ stato and noticed green fluid on the sump, mmm I thought. Crawled under further and the welsh plugs are weeping, ie the two large ones towards the rear of the engine on both sides. Now they look as if I could change these with the motor still in place (albeit removing the starter on one side and the exhaust pipes also). Has anyone done this before, I've only ever done them on a red 6, V8 ones are new to me. Also what have people found the best for getting them out? I know using a suitable size socket was a good way to put the new ones back in, is that still recommended? Thanks in advance.
Peter
peterwmh Offline
#2 Posted : Wednesday, 20 June 2007 8:41:06 AM(UTC)
peterwmh
Also are they 1-5/8 inch, I have a few of these at home so if they're the right size I may as well use them! Ta
Peter
BlaDe Offline
#3 Posted : Wednesday, 20 June 2007 7:54:04 PM(UTC)
BlaDe
when i did it on my 253 i took the trans out and just punched a hole in the plugs with a screwdriver and put the screwdriver on an angle to get them out
#4 Posted : Wednesday, 20 June 2007 10:02:32 PM(UTC)
Blade just about covered how I've done them. Often also heard of people using loctite or sealant on the new ones too. If those ones are corroded there is a good chance all the others are too.
If
peterwmh Offline
#5 Posted : Wednesday, 20 June 2007 11:23:44 PM(UTC)
peterwmh
Yeah that's what I'm worried about, I guess I will do all I can get access too and hope the rest hold on for a while. I really don't want to pull the engine ot tranny out at this stage!!
Peter
