jayHK69 Offline
#1 Posted : Sunday, 20 May 2007 7:16:19 PM(UTC)
jayHK69
can 461 fuellie heads be used on 307 block ? bore will be +60 thou
dca1042 Offline
#2 Posted : Sunday, 20 May 2007 7:29:06 PM(UTC)
dca1042
yes you can,if valves are 1.94/1.5,valve lift not to high,post up cam details,for me,cheers dave
Edited by user Monday, 21 May 2007 4:09:00 AM(UTC)  | Reason: Not specified
jayHK69 Offline
#3 Posted : Sunday, 20 May 2007 7:52:36 PM(UTC)
jayHK69
thanks dave don`t have cam yet just looking at different options for rebuild, think i might throw a pair of alloys on. jayson
dca1042 Offline
#4 Posted : Sunday, 20 May 2007 11:22:37 PM(UTC)
dca1042
do you have a definate plan on directon of end use of engine.give me some sort of parameters and, i may be of assistance,vehicle intenton,auto,man,diff gears, street/strip or street only,cheers dave.
ozchevy Offline
#5 Posted : Monday, 21 May 2007 2:19:43 AM(UTC)
ozchevy
Last time I looked at a pair of 461's they had 1.5 exhaust valves, "maybe I'm wrong" but I've never seen that combination before. They are an old casting though - 1967-68
dca1042 Offline
#6 Posted : Monday, 21 May 2007 4:06:08 AM(UTC)
dca1042
oz chev your probably right,but over the years wear and tear takes its toll,2.02/1.6 are sometimes upgraded to due seat wear etc,i have 2 sets of 291 casting heads(1 set straight2.02/1.6,,1 set angle plug,this particular set was modified for a class racer
Edited by user Monday, 21 May 2007 4:13:20 AM(UTC)  | Reason: Not specified
jayHK69 Offline
#7 Posted : Monday, 21 May 2007 4:29:14 AM(UTC)
jayHK69
thanks dave, as i said just looking at options at the moment but any help is appreciated.
mate basicaly looking at a weekend cruiser with a good bit of poke when you hit the go peddle. currently bore is +40 with what i would guess is stage 1/2 cam (as i
dca1042 Offline
#8 Posted : Monday, 21 May 2007 6:18:52 AM(UTC)
dca1042
how does the engine run(just/good/needs a bit more)category.cheers dave
jayHK69 Offline
#9 Posted : Monday, 21 May 2007 6:35:05 AM(UTC)
jayHK69
engine runs ok, but blows a bit of smoke (especially when you put your foot down)& very heavy on fuel,no. 2 plug keeps fouling. recently had the heads off (over heating problem) & the top of no.2 piston didn`t look too healthy.there are 2 areas with scoll
dca1042 Offline
#10 Posted : Monday, 21 May 2007 7:40:26 AM(UTC)
dca1042
sounds a little sad,better pull it out,strip and check out or locate another.keep us posted.cheers dave.
Guest (10)
