#1 Posted : Sunday, 20 May 2007 11:23:28 PM(UTC)
The electronic ignition on my 186 red motor (Toyota Caoster conversion) has died, there is no spark at all . I have replaced: modulator, coil, dizzy cap, rotor button, ignition leads, all to no avail. What else can be wrong? Have I replaced the wiring correctly, positive to positive side of coil?
#2 Posted : Sunday, 20 May 2007 11:38:41 PM(UTC)
Hi manxboy2.
Is this a Bosch HEI dissy of a Blue motor 173/202. If it is, the most common fail is the reluctor pick-up. They fail far more often than the module, but the poor old module gets the blame every time.
Dr Terry.
#3 Posted : Monday, 21 May 2007 3:03:35 AM(UTC)
Hi Dr. Terry. many thanks for your prompt reply. However in my ignorance I do not know even know what a reluctor pick up is. Could you please enlighten me? Cheers, Phil
#4 Posted : Monday, 21 May 2007 3:38:18 AM(UTC)
Hi Phil.
There are only 2 electronic components in a Bosch HEI dissy, the little black 4-pin module(you've already replaced) & on the inside is the pick-up coil with the 6 'pointy bits' on its inner diameter. Inside that is the 6 pointed rotor attached
#5 Posted : Monday, 21 May 2007 4:59:55 AM(UTC)
I can`t thank you enough. That is obviously the problem. A pity the local auto lecky`s are not so well informed. Cheers, Phil
