#1 Posted : Tuesday, 22 May 2007 7:40:44 AM(UTC)
In my VH i have a 308 with TH400 trans & 10 bolt diff/mini spool 4.44 gears. Speedo has never worked properly and i'm trying to get things sorted out, so it at least works semi accurately. Have got the new speedo cable sorted, but can't work out which speedo gear i should be using- lots of confusing codes and colours. Can anyone give me some advice??
Brett
#2 Posted : Tuesday, 22 May 2007 8:08:50 AM(UTC)
Also do i need the speedo cable with or without adapotor??
shouldntastarted Offline
#3 Posted : Tuesday, 22 May 2007 10:45:11 AM(UTC)
shouldntastarted
If you post tyre size/profile as well someone should be able to do the calculation for you.
The mind is like a parachute! It works far better when open!
Edited by user Tuesday, 22 May 2007 10:45:44 AM(UTC)  | Reason: Not specified
#4 Posted : Tuesday, 22 May 2007 4:18:22 PM(UTC)
The 4.44 was never available in a 308 TH400 Holden. I think 3.36 might have been the shortest gearing, possibly 3.55. I know the C20 trucks with TH400 boxes and 4.10 or 4.56 gearing had adapter boxes for the speedo drive. I'll have a look and see what I c
#5 Posted : Tuesday, 22 May 2007 10:02:22 PM(UTC)
Cheers Guys- the car has 17" wheels, with 45 profile tyres if that helps.
