3 Pages<123>
#21 Posted : Wednesday, 6 June 2007 5:17:41 PM(UTC)
Yes a GTS 350 sedan would be higher on the "muscle car tree" but not rarer than an HJ LS, the original statement. As you know rare does not make valuable and yes you might move heaven and earth for a GTS 350 4 door, but many would rather have a 202 powere
#22 Posted : Wednesday, 6 June 2007 9:45:43 PM(UTC)
Hi Guys.
The muscle car definition probably differs between the USA & Australia, but if we stick to the US definition, as Warren Turnbull has quoted, it does bring up many anomalies.
To quote Warren, “This is why an HQ GTS 350 is not a muscle car,
#23 Posted : Wednesday, 6 June 2007 10:44:05 PM(UTC)
What about the fact that once A9X production was started you couldn't get a 308 in the rest of the LX range? Does that hold water in making is a muscle car?
In the end though, I cannot see how anyone into Monaros woudn't classify a GTS 350 (whether it
#24 Posted : Wednesday, 6 June 2007 10:51:01 PM(UTC)
Terry, the 350 in the HQ was available in LS and GTS therefore not a muscle car was the point. 308 in Torana is different to 308 in Holden, as pointed out. This was the original concept of the Muscle car, a big engine from a larger car stuffed into the sm
#25 Posted : Wednesday, 6 June 2007 11:36:27 PM(UTC)
Hi Warren.
I stand corrected on the VZ Monaro CV8, it does have 260 kW. I was only counting the Hi-Output 250 kW version, so yes it belongs on the list.
I misconstrued your second sentence in that paragraph (“The A9X is an interesting one, as it doe
#26 Posted : Thursday, 7 June 2007 1:25:35 AM(UTC)
yes true. but who cares what it's called. would you like to drive it when new. in it's hay! day. as the bee's knees. ect ect. brabham torana? ha ha.
#27 Posted : Thursday, 7 June 2007 3:16:05 AM(UTC)
Sorry was not aware that GM-H contracted the VK and VL versions of the HDT group A, I thought they were HDT, which is a seperate manufacturer, please correct me if I am wrong, it would be nice to break the dozen mark. (not many is it)
I know the Brabha
#28 Posted : Thursday, 7 June 2007 4:27:48 AM(UTC)
What about a HD/HR X2 or HR 186S? Or the EH S4 before the mods became standard?
Also, just for the sake of the argument, just assume that Holden never put the 350 into the Statesman and LS, making it no argument that the HQ 1837 coupe is a muscle car.
#29 Posted : Thursday, 7 June 2007 4:41:08 AM(UTC)
1) X2 and 186S was an engine option across the board, was available in anything, including utes and vans. EH S4 was not an engine option just a gearbox option and some other nice things, and I am still to be convnced they were made by GM-H (sorry Terry no
#30 Posted : Thursday, 7 June 2007 5:10:36 AM(UTC)
Here's some more "contenders":
The SLR5000 pre the release of the L34 option. It was a Stand alone "sports" version of the LH, with an engine available only in that range in that car, and the most powerful engine in the range.
Were there any special
jabba Offline
#31 Posted : Thursday, 7 June 2007 6:30:11 AM(UTC)
jabba
Back on the subject of HJ codes, there are a couple that I am looking at. The tidier of the two has the following numbers:-
Model 8wq69JR
Body 331532-s
Trim 1900-60V
Paint 567 - 15946
Eng L31 Trans M41 rraxle GU4
Is now running a 350 chev, slig
#32 Posted : Thursday, 7 June 2007 7:41:09 AM(UTC)
Hi Jabba.
It looks like a real HJ GTS 4-door, originally 5.0-litre TH400, painted Persian Sand (Mk I) Metallic & trimmed in Chamois/Covert Vinyl trim.
Dr Terry.
jabba Offline
#33 Posted : Thursday, 7 June 2007 7:47:57 AM(UTC)
jabba
Cool. And a right b^gger too. Was going to get it as project / street rod, but looking at info here, may be too good to muck about.
(And the nice chap selling it doesn't want over much for it, either)
j
#34 Posted : Thursday, 7 June 2007 8:36:45 AM(UTC)
what about the UC torana fitted with the turbo as a option?? or the Apache FB Special that had a factory fitted Canadian grey, wasnt that holdens first "factory special" & wasn't the 327 avaliable in the Brougham, making the HK GTS 327 a non contender???
#35 Posted : Thursday, 7 June 2007 8:38:22 AM(UTC)
Dr Terry.
Hi Guys.
To quote Byron: -
“under the "A9X rule"
To quote Warren: -
“so the A9X clause does not apply here.”
Have I created a monster here?
Seriously though, we should create an ‘Official Muscle Car’ list & have a proper debate
#36 Posted : Thursday, 7 June 2007 8:54:38 AM(UTC)
Hi Monaro202.
I missed your post while I was writing mine.
Were do I start.
Firstly, the Canadian Grey is a bigger myth than the EH 179 HP, it simply does not exist. ALL Grey motors, with the exception of hose in the first few (1946) FX prototype
#37 Posted : Thursday, 7 June 2007 5:38:36 PM(UTC)
The RPO83 as a whole probably should qualify due to the carby, the exhaust and other mods - this is basically the L34 in Ford form. But as far as I know no two of these are the same (there probably were 2 the same but i'm just trying to make a point) as F
Edited by user Thursday, 7 June 2007 5:41:27 PM(UTC)  | Reason: Not specified
#38 Posted : Thursday, 7 June 2007 6:16:58 PM(UTC)
Byron,
They did run out of 327s and fitted 350 block 327s to late HK GTS 327, so had they gone the sandman thing in the hK and fitted 327s, they would disqualify the GTS327, but they did not fit the 350 to the HQ sandman so they more than likely would
#39 Posted : Friday, 8 June 2007 12:13:28 AM(UTC)
I think that they do qualify, but not the SS 5000 as it was simply an engine option rather than a model in it's own right. See my point on the new post on this.
If we all had the same (good) tast
iitsmint Offline
#40 Posted : Friday, 8 June 2007 12:48:24 AM(UTC)
iitsmint
hI ALL, the main thing in all this is the hj ls, its up to individual taste, so what if its a ls instead of a gts, besides Im sure that when the car was ordered, if the purchaser so desired they could have gts options fitted such as dash, maybe seats and
Guest (10)
3 Pages<123>
This page was generated in 0.091 seconds.
