peterwmh Offline
#1 Posted : Friday, 25 May 2007 3:38:08 AM(UTC)
peterwmh
Hi all,
Just wanting to know whether a set of 14x6 alloy mags from a VN will fit a base model VP wagon? A tyre joint here in Wodonga thinks that I'll need 15 inch wheels as the front brakes were bigger!! Is that true or are they spinning a tale to me to try and get a sale?? It's a friends car and they're away at the moment so I can't see the car, I thought they were running 14 inch rims but I may be wrong
Peter
#2 Posted : Friday, 25 May 2007 4:13:44 AM(UTC)
you can fit 14's to vn vp vr vs there all the same brakes and hubs and rotors you just can not fit them to the front of hsv's as the have a brake upgrade ther spining a big 1.
#3 Posted : Friday, 25 May 2007 4:34:25 AM(UTC)
Hi Guys.
That's not quite correct hqmonaro. The last Commodore fitted with 14" wheels was the VP Series I. All Commodores from VP Series II onwards use the larger front brakes, that were previous used mainly on V8s from VL onwards (VL Turbo also). 14"
peterwmh Offline
#4 Posted : Friday, 25 May 2007 4:41:40 AM(UTC)
peterwmh
Thanks to you both, I've got the wheel sizee now, they are 205/65-15 on the car, so maybe I'll need to run 15s. The car is a 1993 model, so I'm thinking it may be series 2, would that be correct?
Peter
#5 Posted : Friday, 25 May 2007 4:55:41 AM(UTC)
Hi Peter.
Yes, VP Series II began production in October 1992.
Dr Terry.
peterwmh Offline
#6 Posted : Friday, 25 May 2007 4:59:43 AM(UTC)
peterwmh
Thanks Doc, now I know.
Regards
Peter
#7 Posted : Friday, 25 May 2007 5:36:42 AM(UTC)
i was talking about ther run the same pads all the way and i only ever stick 14's on the back. and yer dock the vr s run floting discs what sort of work shop do you have
#8 Posted : Friday, 25 May 2007 10:48:18 PM(UTC)
It's funny how these things come up in batches we were discussing it just last week but under a completely different title:
http://www.fastlane.com....topic.asp?TOPIC_ID=11456
Jim...
Guest (8)
