#1 Posted : Monday, 25 June 2007 10:03:20 PM(UTC)
AS question states, is this possible?
cheers,
Ryan
Dmax Offline
#2 Posted : Tuesday, 26 June 2007 7:51:32 AM(UTC)
Dmax
Both will go in no dramas, but I would recommend the windsor for more room.
648hp Tunnel Rammed 351, It does not get any better
#3 Posted : Sunday, 1 July 2007 8:54:40 PM(UTC)
you may need to slightly modify the fire wall to stop the engine from hitting it when you excellerate but other then that is pretty straight
forward
Dmax Offline
#4 Posted : Tuesday, 3 July 2007 5:17:41 AM(UTC)
Dmax
I maybe wrong but I thought the XF engine bay would be identical to the XE and XD which both came out of the factory with Clevos in them, no dramas.
[img]http://i79.photobucket.com/albums/j154/dmax85
#5 Posted : Wednesday, 4 July 2007 1:19:25 AM(UTC)
No for some reason Ford changed the firewall slightly on the XF where the heater hoses poke through (they sort of put a bulge in it). I think it was to allow for more room under the dash for a bigger heater core.
