peterwmh Offline
#1 Posted : Tuesday, 26 June 2007 6:57:39 AM(UTC)
peterwmh
Just wondering if anyone out there has a bit of experience with UHF radios? I fitted a GME Electrophone TX470 to my Statesman yesterday that was a good worker but now transmits OK but won't receive. I'm just wondering if anyone has any ideas, the only thing I had to do was make a new connection on the aerial cable for a new plug that goes into the back of the radioset. I hope someone out there can help.
Bye for now
Peter
#2 Posted : Wednesday, 27 June 2007 12:12:13 AM(UTC)
Not in "duplex" mode is it where it transmits on one channel & receives on another?
It ****s me to tears when the media & state politicians refer to t
peterwmh Offline
#3 Posted : Wednesday, 27 June 2007 4:09:18 AM(UTC)
peterwmh
Unfortunately no, however I think it may still be a short in the antenna plug into the back of the unit.
Peter
basketcasebear Offline
#4 Posted : Wednesday, 27 June 2007 6:16:44 AM(UTC)
basketcasebear
eerrhh? what is a uhf radio, and what does it do? is it a CB??
ptpro
DOH!!!
#5 Posted : Wednesday, 27 June 2007 9:38:59 AM(UTC)
yep it is your common or garden variety CB.
You get fewer idiots on UHF as most use AM or SSB (single side band).
But uhf is clearer but does not have the same range as am/ssb.
There are a lot of repeater aerials along most country roads to help uhf, b
#6 Posted : Saturday, 30 June 2007 3:51:35 AM(UTC)
Make sure your inner and outer cables are not touching each other at the connector when you connected it to the cable, If you can disconnect the cable from the aerial use an ohm meter to check an open circuit. If you cannot disconnect cable ther will be a
