camlj Offline
#1 Posted : Thursday, 31 May 2007 6:03:57 AM(UTC)
camlj
i've got the steering shaft out of a vk commodore but need it a bit longer for a different application. does anyone know if any other holdens used the same shaft (ie same diameter and spline) but in a different length? cheers.
#2 Posted : Friday, 1 June 2007 12:11:15 AM(UTC)
Your best bet might be to look at the shaft from a VE as they had front mounted steering racks. I don't know about the spline being the same though.
I
camlj Offline
#3 Posted : Friday, 1 June 2007 5:10:21 AM(UTC)
camlj
thanks mate i'll give it a try
#4 Posted : Friday, 1 June 2007 5:31:09 AM(UTC)
The non-power steer cars had a longer shaft out of the column compared to the ones with power steer.
May be all you need.
A lot of people aim to achieve nothing in l
